4 runner 22re alternating idle - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 05-19-2005, 09:25 AM   #1
........Yes it's me again and I've limited all the problems except my changing idle. I just had the valves adjusted after 500 mi on the new engine, they checked that I put all the vacuum lines in the right places and that the TPS was set correctly (thanks to you guys) but they say there still may be a fuel system problem but I made them stop searching aimlessly when the bill reached $430! They did the 4 gas analyzer and all is good other than being a bit rich which they say could be because of the K&N filter or maybe an oxygen sensor issue(which I cleaned before the install). Any ideas??? Sometimes the idle will be right around 800 but often it will stay up about 1300??? Other than that it runs great, smooth power delivery, good mileage compared to the old engine............ Thanks for your time and opinions...............TIM
timk2915 is offline   Reply With Quote
22RE low idle / hard start Sandman 86-95 Trucks & 4Runners 5 07-23-2015 09:15 PM
22re rough idle and stumbling Yont283 84-85 Trucks & 4Runners 6 07-07-2015 06:59 PM
Why is Battery Leaking? bigblue82 General Electrical & Lighting Related Topics 10 07-06-2015 09:27 AM
Idle dying/check engine light sonic concepts Newbie Tech Section 0 07-01-2015 03:33 PM
Update on Second Guess bobbybouche 86-95 Trucks & 4Runners 0 06-18-2015 11:22 AM
Tags
4gas, alternating, analyzer, idle, yotatech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
