4.5" lift and 315/75R-16??
I`m thinking of moving up to 35s but need to know will my lift (2.5) plus RB 2" lift be enough to clear them 35s?
I`ve read his site thoroughly and that is why I think 2" BL instead of 1" plus hammering/cutting this. I don`t want to do that. So those Yokohamas will fit with 4.5" lift?
Originally Posted by HOJU
Jboy i'm not familiar with your lift, what are the 906's? what's in the front?
It`s closer to 2" in the front but I will be replacing the coils/spacer with the Tundra TRD coils for that xtra 1/2" lift. I`m not so worried about the rear.
Couldn`t sleep last night so I got to read that 17 page thread about the TRD Tundra coil lift. So fitting those 35s requires the stock A-arm modification? Looks like it`s going to a bit more involved there.
Well,
Hoju stuffed his in there somehow. You could also use wheel spacers. You will get a little extra lift with the A-Arms and you have to be careful with those CVs! I want 35s also, but there is just too much other stuff I want right now. The rig is getting put on the back burner for alittle while while I get some stuff that has a little practicality.
well the a-arms are a must in my view, and i also have a different suspension setup, those 882's gave me 3" lift, and with trim packers in the rear, i had 3.5" BEFORE the body lift. so after i ended up with 5"/5.5" lift.... soon to be 6.5 in the rear with the rear bumper and cornfed pucks going in-
justdifferentials
09-05-2015 06:52 PM
joeynational
09-05-2015 01:54 PM
