3rd gen Window problem
Old 07-28-2005, 05:41 AM
Del34's Avatar
Just in the past week or so, I've had 3 instances where my driver side window doesn't want to work. It won't go down, and it won't go up, however, it doesn't take long for it to finally kick in and start working fine again. Also, it's ONLY the driver side front window. Every other window functions just fine.
Any idea what the cause of this might be? Maybe the wire isn't connected real snug or something? I plan on checking it out later, but just wondering what the cause might be.
Old 07-28-2005, 06:11 AM
2ToyGuy's Avatar
I'm no expert in power windows, but it sounds like dirty/corroded contacts in the switch. Has it had any kind of liquid get in/on it lately? Or even just dust/dirt, whatever. It could also just be wearing out, the driver's side getting, overall, much more use than the others. Just a few thoughts...
Old 07-28-2005, 06:35 AM
Del34's Avatar
Actually, you are probably pretty much right on. I recently just got back from the Outer Banks, so obviously my truck saw a lot of time on the beach, thus sand and whatever else may have made it's way in there.
I guess I could try to get one of those pressurized air cans and try to spray around that area.
Thanks...I'm betting that's probably the reason for the whole problem.
Old 07-28-2005, 07:07 AM
2ToyGuy's Avatar
Salt air a REALLY harsh on electriclas, too. If the contacts were getting close to failure due to corrosion or use, then I'd bet the salt air out there on the beach has pretyt much finished the job. I don't know if it's feasable, but a quick-fix until you can get a replacement might be to swap teh switch out with one from another window...
06-01-2021 01:51 PM
mskalmus
05-28-2017 07:51 AM
jerusry
10-19-2015 05:28 PM
tpd143
07-07-2015 09:06 AM
coryc85
07-06-2015 04:07 AM
Quick Reply: 3rd gen Window problem
