YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 06-04-2009, 09:47 AM   #1 (permalink)
Personal Sales Rating: (0)
3rd Gen transfer actuator - DON'T DO THIS...
If like me you are having trouble with your 4wd multimode system, there is a great thread by SC994Runner.
But, if you suspect the transfer case actuator assembly, BE CAREFUL when opening the actuator itself. There is a gear inside that is driven by an electric motor. (motor sits on top in a black plastic cover)
If you pull the actuator (gear) cover off to check the terminals and accidentally, the gear comes out as well, you will need to clear your calender 'cause its a b@stard to get back in, and to get it back in at the correct rotational angle.
I have this problem,
UNLESS anyone can shed some light after being in the same boat.....
Ash.
ash-ssrg is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 10-28-2009, 08:58 AM   #2 (permalink)
Hi, I believe the actuator on my 1996 Tacoma 4X4 Automatic is sticking....... do you have any idea on how to gain access to the inside of the actuator to lube it up without having to remove the actuator from the truck all together?
__________________
1996 Tacoma V6 4X4 SR5 Extended Cab Automatic
kennyyoung is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
2002, 2004, 2006, 3rd, 4runner, 4wd, 4x4, 955, actuator, case, engagement, generation, problems, removal, tacoma, test, toyota, transfer
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Transfer Actuator? rputt 95.5-2004 Tacomas & 96-2002 4Runners 2 03-24-2008 06:08 AM
4WD Transfer Case Actuator Potomacduck 95.5-2004 Tacomas & 96-2002 4Runners 6 09-25-2007 05:25 AM
Need Some Advise on Transfer Case and Actuator vtruong1 95.5-2004 Tacomas & 96-2002 4Runners 1 11-14-2006 03:57 PM
4WD Actuator 3rd Gen. Potomacduck 95.5-2004 Tacomas & 96-2002 4Runners 4 09-29-2006 08:28 AM
Leaking Transfer on 3rd Gen? BASSMAN 95.5-2004 Tacomas & 96-2002 4Runners 12 06-14-2004 07:47 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
