3rd Gen Tire Size w/1" Body Lift?
Old 11-08-2003, 10:15 AM
TheLaw's Avatar
What's the largest tire that can be put on a 3rd gen with only a 1" BL? I would prefer to not trim the fenders...
Old 11-08-2003, 10:52 AM
RTdawgs's Avatar
then stick with 265/75/16
Old 11-08-2003, 10:54 AM
Cmar's Avatar
What about the 275/70's, will they fir or would you need a 2" BL
Old 11-08-2003, 01:17 PM
Jonathan's Avatar
You may be able to fit the 275/70's, That tire is about a 31X 10.80 size(but remember width will you kill you more than hight). I would just stick with the 265/75. With only an inch you can't go much higher or wider than that without a lot of rubbing.
Old 11-08-2003, 03:45 PM
INsr5runner's Avatar
I was running 265/75/16's without any lift, and the only reason they rubbed is because I have a 16x8 wheel, instead of the stock 16x7. If you have the stock rims, then 265/75/16 should not rub at all.
smthwsn357
12-04-2023 02:08 AM
06-01-2021 01:51 PM
09-04-2015 09:27 AM
Yotoder865
07-09-2015 07:51 PM
MTLroadierunner
07-06-2015 12:17 PM
Quick Reply: 3rd Gen Tire Size w/1" Body Lift?
