3rd gen runner alternator...did your light come on when it died?
Old 08-14-2015, 03:13 PM
sharrack's Avatar
3rd gen runner alternator...did your idiot light come on when it died?
Mine did not.....i got lucky though.
Anyone have any issues with a duralast alternator from Autozone?
Has anyone found a way to fix the idiot light dilemma because i'm sure it has stranded more than a few owners.
kenny s
Old 08-15-2015, 01:13 AM
wyoming9's Avatar
Red face
I have a voltmeter in all my vehicles I like to keep a eye on system voltage .
It seems all the reman electrical parts these days the quality has really declined.
Are you able to rebuild yours or maybe have it done local?/
Then the down time is always a factor!!
I priced a new one at my dealer a while back it was not that bad.
Perhaps check Rock Auto for a new Denso.
Good luck!!
Old 08-15-2015, 12:08 PM
sharrack's Avatar
yea.....one vehicle with no down time. I just put in the autozone lifetime warranty alternator. I'm still puzzled as to why the voltage idiot light did not come on and why Toyota would put a temp gauge instead of a big red light?? I've had my temp gauge pinned hot and unless you look....You're engine is gonna blow!
So....i can be discharging or overheating and never realize until its too late. Crazy!
Old 08-15-2015, 01:02 PM
wyoming9's Avatar
Red face
You don`t check your gauges when you check your side mirrors
Old habits needing to check the air pressure gauge
Don`t know why your light failed to come on might be a 4Runner glitch.
If I cause a under voltage situation my 2000 Tacoma light will come on.
Old 08-15-2015, 07:10 PM
TheDurk's Avatar
Dumb question: did you check the bulb?
(It should come on with the key before engine starts.)
Often if the bulb is dead the alt. will not excite and, obviously, you won't get the light on to tell you there is a problem.
To check the warning light circuit, turn the ignition switch to the “on” position without cranking or starting the engine; if the idiot light does not come on, remove the plug from the alternator and ground the sense wire (wire connected to the bulb--yellow/green wire on pin 1 on a '99 4Runner--yours might be the same.) If the light comes on, the wiring is okay but the alternator is defective; if the light still does not come on, the wiring to the light circuit and the bulb should be checked.
Old 08-16-2015, 12:57 AM
wyoming9's Avatar
Red face
I had thought to mention the light working but that was pretty much a no brainer !!
Old 08-16-2015, 04:51 PM
sharrack's Avatar
Key on engine off.....battery light works. I'll have to test the wire at a later date.
I got lucky at autozone because the guy switched out my battery at no charge for a new one and then rechecked the system and found it discharging.
The whole situation could have been real ugly if i were out in BFE like i am quite often.
You know.....70 miles to the nearest gas station......only border patrol to help you.
Old 08-18-2015, 05:22 PM
aowRS's Avatar
How long do the factory units commonly last? I'm at 14+ years and 335,000+ miles on the original...
Andreas
Old 08-19-2015, 12:19 AM
wyoming9's Avatar
Red face
Really know way to tell
It depends on how much oil, liquid brine and etc. gets into them
I have two here that have so much corrosion inside they just quit working even after soaking in Kroil the screws just snapped off now pretty much junk.
Old 08-27-2015, 12:12 PM
sharrack's Avatar
mine lasted 230,000 miles.
The real scary thing is that there was no warning. just a slow turn over one morning....then dead leaving work. Got jumped at work and got a new battery at autozone.
For giggles the guy said let throw my tester on to make sure you are charging. I was not charging!
I have an Arizona truck so things just last longer here with no snow, road salt or continuous wet weather to rust things out.
Old 08-28-2015, 09:03 AM
KZN185W's Avatar
normally it's the IC regulator that dies and since this part controls the circuit to & from the alternator, then no warning light lits up. you'll just have to regularly check the battery to see if it's charging properly.
Old 08-29-2015, 01:29 AM
wyoming9's Avatar
Red face
That is why I like having a Voltmeter on the dash to keep an eye on the electrical system.
Old 08-23-2016, 12:19 AM
superduper's Avatar
hello
Been having issues with my 98 4runner lately but I can't pinpoint the problem. My battery light sometimes stays on at first start and intermittently turns off/on. This happens mainly when I press the gas from a stop, stays on for 5-10 seconds and turns off. This also happens even in the middle of the freeway. Connected a voltmeter and readings seem fine: 12+ when engine is off, between 13.75 - 14.25 when running. I do notice big drops when I press on all 4 window switches at same time. 4runner starts fine, never sputtered or dies. Battery is less than a year old. I believe I still have the original alternator from 98 and have 270K miles. Please help. should I just change the alternator or try a new battery? Any advice will be appreciated. Thanks.
Just some history: recent work done was timing belt kit (water pump, timing belt, drive belts, etc.) about 5 months ago. no problems popped up till now.
Old 08-23-2016, 05:39 AM
superduper's Avatar
Also sometimes in the morning when I start the car and the battery light would stay on for quite a while. I connected the voltmeter and it read 12+ While the engine is running
Old 08-23-2016, 08:39 PM
wyoming9's Avatar
Well 12 + VDC is not good!! while running should be up around 13.5 to 14 VDC
Is your belt tight ??
AustinTaco
08-22-2022 10:45 AM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
peterbilt
06-11-2002 10:28 AM
95Runner
06-09-2002 08:56 AM
Quick Reply: 3rd gen runner alternator...did your light come on when it died?
