3rd gen comparision of 1in lift pics
Old 02-18-2006, 03:56 PM
FUZION's Avatar
I'm kind of stuck in between whether to go with the tundra lift or just the 99 coil lift. I dont wheel at all so im guessing the tundra lift might be over the top. For those of you who lifted your 4runner an inch can you post before and after pics. thanks
:chicken:
I have a 97 2wd so im hoping maybe the 4wd coils give me ~1 1/2 inches
Old 02-18-2006, 04:10 PM
ebelen1's Avatar
Look at any of the guys/gals that have the PP/Bilstein combo. They should have about the amount of lift you're looking for. Off the top of my head, Bob_98SR5 and Lee both have this lift. They both should have profiles in the 3rd gen gallery.
Old 02-18-2006, 04:40 PM
FUZION's Avatar
Thanks for the good leads!
Old 02-18-2006, 04:44 PM
calg3's Avatar
You can see pics of my 4Runner with the PP/Bilstein combo here:
http://www.4x4wire.com/cgi-bin/galle...jpg&img=12&tt=
and in my signature. Also check with aowRS he did the 99 spring swap on his 4Runner
Old 02-18-2006, 04:52 PM
FUZION's Avatar
thanks, is it a 2wd
Old 02-18-2006, 04:54 PM
Bob_98SR5's Avatar
plan for the future: do you want larger tires? if so, how big? if 32", the 99 springs will cut it, but just barely. the PP 1" springs would be a better choice if you plan to go to 32"s. if larger tires, then you have many choices, too numerous to list off the top of my head
bob
Old 02-18-2006, 04:58 PM
FUZION's Avatar
I already have 32"s and thats as big as im going. I only rub if i hit a big dip while turning. i like the pp springs but theyre $300 for the front and rear.
Old 02-18-2006, 05:02 PM
FUZION's Avatar
Does anyone know who's green 4runner with black wheels is displayed on the top.
Old 02-18-2006, 05:08 PM
garrett1478's Avatar
good luck finding out...
Old 02-18-2006, 06:11 PM
ebelen1's Avatar
Yeah, the PP springs and OME for that matter are expensive. If you're not gonna go off-road, just go w/ the '99 springs. You should probably also swap out shocks to 4x4 ones since the '99 coils will be taller than your 2WD springs.
Old 02-18-2006, 06:16 PM
Localmotion's Avatar
i thought that was Christians 4runner? <96 Runner>
Old 02-18-2006, 06:37 PM
i dunno, may be, its the fact that the banner constantly changes that makes it hard to figure out who's who.
Old 02-18-2006, 07:22 PM
FUZION's Avatar
thanks, that was him. he has the 1in body lift, which is a good height for me
Old 02-18-2006, 07:23 PM
FUZION's Avatar
is it necessary to sway out the shocks
Old 02-18-2006, 08:12 PM
jwbehm's Avatar
Sorry to hijack this thread, but will 265/75/16's fit with the stock 99 4wd springs?
Old 02-18-2006, 08:18 PM
FUZION's Avatar
yes, it'll fit with any year
Old 02-18-2006, 08:22 PM
ebelen1's Avatar
It's not necessary but a good idea. You have a '97 and if you haven't changed out the OEM shocks, they're probably pretty beat up. Have you noticed uneven tire wear, cupping, etc? This could be a sign that your shocks are no longer working as intended.
Plus, swapping out the front springs is the same labor when you change the front shocks. The rears are different so they don't count for this last sentence.
Old 02-18-2006, 08:23 PM
ebelen1's Avatar
If you do a 1" bl, you don't need to worry about alignment or changing out any of your suspension parts. This is definitely a cheaper way to go to get lift plu it will help in your slight rubbing issues as well.
Old 02-18-2006, 08:30 PM
FUZION's Avatar
all my tires have worn evenly. I can get both the body or coils for about the same price. It's all about what's easier to install.
Old 02-18-2006, 08:33 PM
FUZION's Avatar
is an alignment necessary with the 99 coils
Quick Reply: 3rd gen comparision of 1in lift pics
