3rd Gen Audio Question
This friday coming up Im getting my audio system installed. I have the limited with the cd, cassette and radio deck, question is, does the cd player have the brackets, or would the installers have to order it?
http://www.crutchfield.com/cgi-bin/S...176T21&o=m&a=0
Oh and its 51/4 for the rear doors with no mods right?
thanks
thanks
Rear doors should be 5 1/4's ( I haven't changed mine out yet ) and you will need no additional brackets, however you will need a toyota pocket to go underneath the radio (assuming you bought a single din unit) since your factory is double din. You also have a factory amplifier underneath the factory radio that will simply unplugged to bypass it (takes less than a minute).
Good luck, hope it turns out good!
Im not going to need that pocket no more because I am installing an equalizer right under the single DIN unit Thanks for the goodluck, I hope it turns out good.
Anbody want the factory CD/Tape/Radio deck for a reasonable amount after it has been removed from the rig. The rig will go in this friday and hopefully be out by the end of the day, just lemme know. thanks
westside@mountaincable.net
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
vanion2
07-29-2015 06:17 PM
