3rd Gen 4WD problem
3rd Gen 4WD problem
Hello,
<My 02 Runner front wheels engage hard every time I accelerate when on H 4WD/ cent-diff unlocked. The front end fells much like going over a small bump on the road everytime I step on the gas even on straight line and level ground. I feel it could be a motor mount, a bad diff, bad transfer case, or even a synch/electrical problem of some kind. My old 01 Runner felt smooth when in this mode. Has anyone experienced this, and if so, what was the problem?
cwcruzer
I have a 99 limited with the multi-mode 4wd like yours. If i'm coasting down the road with the center diff unlock in 4H and my foot off the gas and then step on the gas, i'll get a jolt from the front drive line exactly how you described. If I lock the diff. the jolt disappears. I think whats happening over time is the center diff. develops some clearances and causes driveline slack. I know its really annoying, but the only way I can tolerate it is to change my driving style and being less abrupt with the throttle and apply smooth application to the gas pedal.
Walt
Walt
I think the manual says something about every once in a while going through the different modes and driving a couple miles just too keep everything lubricated and working correctly. Maybe if you just get everything serviced and lubed and keep up some kind of routine of driving in all the modes from time to time it will solve itself.
Originally posted by <96 Runner>
I would recommend going to the dealer since you are still under warranty. A trusted dealer that is.
Thanks
Originally posted by ilocan
cwcruzer
Walt
cwcruzer
Walt
Thanks
Thanks
06-01-2021 01:51 PM
jerusry
10-19-2015 05:28 PM
tpd143
07-07-2015 09:06 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
