| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
__________________
Boogie 1996 4runner |
#2 (permalink) | |
Quote:
There are plenty of other options to choose from.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#3 (permalink) | |
Quote:
It could be the next big thing, I doubt it, but ...it could happen.
__________________
Nate [/font]Suspension: Tundra TRD Fronts w/ Dual 3/8" "TerraBull" spacers: 2.5",Trekmasters, LC's/OEM LC Shocks: 3.5"... Performance: 4" Deckplate, TrueFlow Air Filter, ISR Mod... Shoes: 285/75/16 Nitto TG's, OEM 16x7 (6 spoke)... Armor: Stubbs Sliders... Exhaust: 18" Magnaflow SIDO, Magnaflow High-Flo Converter, 2.5" and 2.25" piping... Other Necessities: Custom Extendable Panhard Bar, Custom Bumpstop Drop Brackets, 1" Diff Drop... |
#4 (permalink) |
Ive never heard of it being done. You'd have to do a lot of measuring, then decide if it would screw up your geometry, and if so, then modify it to work. In the end, it will probably be more expensive, and much more work.
In the end, there are so many options for our model trucks! We have almost as many aftermarket parts as Jeep!
__________________
1996 4x4 3.4L 4Runner on 35's - 6" of lift, MTR's, E-locked, ARB Tacoma Bumper, Sliders and a cut off tail pipe. 1966 FJ40 - SOA with stock springs, stock 1F motor, and a smelly tailpipe. |
#5 (permalink) |
I don't think they are compatible and 4th gen Runners sit lower than most 3rd gens anyway so it really wouldn't be an upgrade. Last gen Tacoma front shocks and coils don't fit 3rd gen Runners.
__________________
'99 4Runner Highlander 4wd E-locker,rear diff and deckplate mod * 265/75/16 Nitto TerraGrapplers * Yakima Load Warrior rack * clear corners/signals * Tacoma skidplate * Silverstar lamps/fogs Alpine CDA-9831,Bazooka EL Series 250w amp,MTX 10" sub |
#6 (permalink) |
We don't have any where near the after market parts jeeps do. Maybe as many as a grand cherokee or something but if by jeep you meant cj/yj/tj there is no comparison.
__________________
98 4x4 limited 4Runner, e-locker, 4.30 gears |
#7 (permalink) |
If they fit, you might have a point, but they don't.
__________________
#8 (permalink) |
it will work if you have a 2wd as the lift will be too much for a 4wd vehicle due to the cv angles being too extreme. someone on ttora did this to their taco and it lifted well over 3" so you can imagine what it can do to your cv's.
if you have a 2wd, do it i guess? but i'm not sure what you do with the rear... if you have a 4wd, you're asking for trouble even if you add diff drops... btw you're still better off doing the tundra lift... check around for info by bamachem (no longer a member here but you'll be able to find him elsewhere).
__________________
2003 4runner SR5 4x4 Chaos Edition Chaos Edition! Operation Rebuild Chaos Edition Need to reach me or ask questions? You can find me here! |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Swap 4th gen Land Cruiser Disc on 3rd gen 4runner | cslainson | 95.5-2004 Tacomas & 96-2002 4Runners | 4 | 11-24-2005 11:04 AM |
| 5VZE 3rd Gen 4Runner / 4th Gen Taco Fan Swap | bamachem | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 07-14-2005 04:56 AM |
| Will 4th Gen rear discs fit a 3rd Gen housing w/ ABS? | aowRS | 95.5-2004 Tacomas & 96-2002 4Runners | 3 | 11-11-2004 01:52 PM |
| WANTED! 3rd Gen Stock shocks and springs, 1999-2002 4WD | sschaefer3 | 95.5-2004 Tacomas & 96-2002 4Runners | 6 | 08-04-2003 06:36 AM |
| How about 1st gen, 2nd gen, 3rd gen and 4th gen? | Fahrenheit 451 | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 01-24-2003 04:46 PM |
