3rd gen 4runner hub problems
well guys bout a week ago i my lower ball joint blew out on me when i was crusin bout 55mph so ive been fixin it ever since then well bout 3 years ago when i did my lift i swaped over to the tacoma manual hubs and after i had the bearings pressed in the passenger side was bad but ive delt with it since then bc it didnt cause that many problems well since i was fixing my car form the ball joint blow out i decided to have it fixed and just after a day of driving its bad again
so here is my question do yall think that the hub, knuckle, or the bearing is the problem or since it was damaged from the beginning that it messed something up because my mechanic told me of no problems that he saw
any help would be appreciated
You sure the mechanic installed it right? I would take it back to him and let him figure it out since you paid him for nothing. If something is screwed up to the point where it failed that bearing immediately, the mechanic should probably noticed that and warned you when he had it apart.
I wonder if he ruined the bearing during install or if it was a defective bearing?? Hard to find out now, but I'm sure we know what the mechanic thinks, haha.
What do you have against friendly puncuation (., are your friends)? Took 3 reads to understand your question...
Did the bearing ever drive well after the LBJ broke? It seems to me the bearing could have been loaded off axis if the geometry changed when the LBJ broke.
Gene
19
06-03-2002 07:07 PM
