YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 09-28-2003, 10:14 PM   #1 (permalink)
mark_fit's Avatar
3rd gen 4runner check engine light on`
anybody ever get a check engine light on with a
lean mixture bank 1
fc 171
i got a 2000 v6 supercharged.
__________________
Y2K 4runner. With a bunch of stuff.
mark_fit is offline
Sponsored Links
To remove this ad, register today!
Old 09-29-2003, 04:07 AM   #2 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Have you done any of the fuel mods yet?
If you have done the ISR, deckplate or elbow mod you might want to reinstall the restriction at least temporarily. If you run a lean condition too long you could do some serious damage.
At the very least you should be looking at some supra injectors and a walbro fuel pump.
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 09-29-2003, 07:15 AM   #3 (permalink)
CTB
CTB's Avatar
Isn't that also that same code that comes up with the MAF sensors need to be cleaned on the 3.4's?
__________________
1995 4Runner V6 4x4
CTB is offline
Old 09-29-2003, 11:18 AM   #4 (permalink)
mark_fit's Avatar
i don't have any fuel mods done yet but after 65k i got this check engine light on for the first time. i did replace the plugs to a colder plug, gapped it to 32'' like trd said, but that is it(10k ago) and while pulling my boat from the lake up a hill it came on..
where should i look to get these injectors, and pump from?
__________________
mark_fit is offline
Old 09-29-2003, 02:40 PM   #5 (permalink)
Quote:
CTB might have something there, totally forgot about that!
Definately check that first and clean it just to be sure.
__________________
- Jamie
Old 09-29-2003, 10:51 PM   #6 (permalink)
mark_fit's Avatar
ok well here is what a toyota independant shop said today.
not to clean the maf because it can damage it.
but they did some diag work (chargered 60 bucks) and told me i need a pre cat o2 sensor bank 1.
this fault does not make sense to me. because it's not showing any o2 sensor faults..
but i can get toyota parts @ cost rather then 139.00 + 60.00 to install it.
should i replace both pre cat sensors.
__________________
mark_fit is offline
Old 09-30-2003, 05:03 AM   #7 (permalink)
I don't think replacing the sensor will help the problem but you are certainly free to try it.
First check for a vacum leak (cracked or unhooked hoses, etc...)
Then check out these threads:
http://www.yotatech.com/showthread.p...n+MA F+sensor
Even better:
http://www.yotatech.com/showthread.p...hlight=02+code
and lastly:
http://www.yotatech.com/showthread.p...lean+o2+ code
Should be enuf evidence to convince you of your problem.
When my O2 sensor went I did not get a 171 code. The 171 means system lean NOT bad O2 sensor....you can curse out the auto shop guys now for their crappy advice. I think it says O2 sensor out of spec or something like that. Do a search on cleaning your MAF sensor and you should be back up and running in no time.
Here is a thread for cleaning it:
http://www.yotatech.com/showthread.php?s=&threadid=3310
Good call again by CTB!
__________________
- Jamie
Old 09-30-2003, 07:30 AM   #8 (permalink)
CTB
CTB's Avatar
Hey, thanks MTL_4runner.
mark_fit - don't worry about cleaning your MAF - tons of guys on here have done it. Just do a search for the many threads on this topic. I'm pretty sure all it takes is a q-tip, some electrical contact cleaner, and a gentle hand.
Let us know what you find out!
__________________
1995 4Runner V6 4x4
CTB is offline
Old 09-30-2003, 09:19 PM   #9 (permalink)
mark_fit's Avatar
ok guys, i cleaned the MAF. Cleared the faults using a buddys scanner, and i will go drive it tommorrow. It looked clean, there is a round bead of like a hard wax at the tip to keep the two wires together. (right) And man were the 2 screws on tight, almost stripped them.
I also got the scanner to keep for a few days, is there anything i should watch for in the ecu doing.
Do toys have any adaption values it goes by? Do they need clearing or just the code cleared is cool..
I took some pics but i can't post them. Anybody wanna give it a shot i'll e-mail them as attachments.
thx guys
__________________
mark_fit is offline
Old 10-01-2003, 10:34 AM   #10 (permalink)
The little bulb thing is only one of the things you need to clean. There is also two thin wires if you look down one of the holes. These also need to be cleaned but are very hard to get to.
I have a 1999 SC'd 4 Runner and also had a P0171 code (bank one lean) and after paying a local shop $65 to tell me that and clear the code, I still had a lean condition in bank one.
Luckily, with the help from Jay here, I was told to clean the MAF. All I can tell you is WHOLLY GOD! It made a HUGE difference in performance. Obviously, it was very dirty.
Mike
PS- I wrote a thread about this titled "Clean your MAF" a while ago.
__________________
4Runner gone- Minivan in it's place- Gotta do what I gotta do.
Does TRD make a supercharger for a Sienna?
mhawker is offline
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
03 4Runner Check engine light rany 03+ 4Runner/GX470, & 05+ Tacomas 12 09-24-2007 05:54 AM
2000 4runner check engine light breck_k 95.5-2004 Tacomas & 96-2002 4Runners 5 12-10-2005 06:54 PM
2ND GEN 4Runner Check Engine Light BMWSTOY 95.5-2004 Tacomas & 96-2002 4Runners 5 02-22-2005 11:47 AM
2nd gen check engine light fooddude 95.5-2004 Tacomas & 96-2002 4Runners 2 11-23-2003 01:50 PM
2nd Gen Check Engine Light AlixTheRunner 95.5-2004 Tacomas & 96-2002 4Runners 11 02-25-2003 08:00 PM
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
