3rd GEN 4Runner 4WD Conversion Parts
Old 12-04-2004, 04:29 PM
kawaii005's Avatar
i found a complete front end off a 3rd gen 4WD 4Runner @ a junkyard. it's bascially the front frame sawed off so it has the diff, axles and complete front suspension. no driveshafts, tranny or transfer case. He wants $200 for just the front diff but i'm sure he'll sell me the whole thing for $250ish since my friend is buying a front axle and a bunch of other stuff for his SAS from him. Is this a good price? How much should i expect to pay for the transmission. transfer case and driveshafts?
THANKS!
1999 4Runner SR5
Old 12-04-2004, 04:45 PM
User 051420's Avatar
IIRC Casey (Nitro Hotpants) did the swap..I think there's a few threads about it.
Old 12-04-2004, 04:59 PM
kawaii005's Avatar
but his doesn't say anything about prices..... and it's a 4cyl. 5spd.....
Old 12-05-2004, 11:14 AM
Nitro Hotpants's Avatar
u are going to want to make sure u get all the vacuum hoses and canister for the ADD diff. i spent 400 for the tranny and xfer case. and paid 650 for diff, axles, hubs, and spindles from a 97 tacoma with 70k miles on it. it would be much easier to get parts from a tacoma so you dont have to mess with electrical systems and vacuum lines. my swap was purely mechanical, no hoses, no wires, none of that junk.
plus manual hubs are cool!
Old 12-05-2004, 11:48 AM
SEAN_at_TLT's Avatar
I agree with using Taco parts if possible. It will make life a lot easier.
Old 12-05-2004, 05:09 PM
kawaii005's Avatar
ok, thanks a lot guys!
Old 12-05-2004, 05:21 PM
kawaii005's Avatar
so all the 4runner diffs will be ADD?
Old 12-05-2004, 07:22 PM
yes, they will all have ADD. some tacomas 95.5-2000 will be available with manual hubs. be on the look-out for those years.
Old 12-17-2004, 01:49 AM
kawaii005's Avatar
Can i run a ADD-equipped front diff and disable the ADD, then just add manual hubs? I only ask because every diff i've come across so far is ADD-equipped.
Old 12-17-2004, 07:29 AM
Babypig's Avatar
You're also gonna need the wiring harness and the ECU.
Old 12-17-2004, 11:17 AM
kawaii005's Avatar
even if i'm not using ADD at all?
Old 12-17-2004, 09:19 PM
kawaii005's Avatar
bump
Old 12-19-2004, 09:41 AM
Babypig's Avatar
Depends if its an auto or not and weather you have an auto or not. I know that if it's an automatic then you'll need the ECU and harness due to differences in the tranny between 2wd and 4wd. If it's a 5 spd I'll be honest, I don't know much about them.
Old 12-19-2004, 11:33 PM
kawaii005's Avatar
my plan was to use the 4WD auto tranny and the ADD front diff, axles and spindles. Then lock the ADD fork over and put manual hubs on. So I have all the ADD components but it will be locked to "on" all the time. I only wanted to do this since all the parts i've come across so far are ADD ones. Will this setup work?
Old 12-20-2004, 07:12 AM
Babypig's Avatar
It should work, but your going to be turning a lot of hardware up front. Your also gonna have to get new axles for the front. You can't just add manual hubs. There is a kit to do them though, not sure how much that is. If your going to use the 4wd tranny you will have to pull the wiring harness and the ECU as well.
Old 12-20-2004, 10:53 AM
the ORS conversion kit is around a grand, if you go from ADD to manual hubs. to be honest, be patient and wait for those taco parts, you will be happy when you dont have to try to "make" the ADD/Manual hub conversion work.
im not sure if you've tried www.car-part.com but give them a shot, its how i found my parts. good luck and be patient!
-Casey
Old 12-20-2004, 12:54 PM
kawaii005's Avatar
ya i was figuring that this would be more work than needed, patience is a virtue, thanks guys!
AustinTaco
08-22-2022 10:45 AM
Jdgarrison
10-01-2015 05:22 PM
Niameyrider
06-25-2015 05:50 AM
infinityisfive
06-16-2015 06:51 PM
westbound
06-07-2002 03:30 PM
Quick Reply: 3rd GEN 4Runner 4WD Conversion Parts
