3rd gen. 3" body lift help??
Old 03-11-2008, 04:05 PM
rig4runner02's Avatar
Question 3rd gen. 3" body lift help??
Help ..I have 3" suspencion lift kit on 4runner 3rd. gen...I woul like to install 3" BODY LIFT ...I've read and there is some steps to do it, but nothing complicated or problematic.Is there anybody that has 3" bodylift on a 3Gen. 4runners? Please help ??? DO IT ? OR DON'T?
Old 03-11-2008, 04:53 PM
d0ubledown's Avatar
4rx has a 3" body lift on stock suspension. pm him. if youre already higher with a suspension lift..why do you want to add that much of a body lift? stick with something a bit less. its not that much more difficult than a 2" body lift. 4crawler should be able to hook you up with everything you'll need to get it setup right.
Old 03-11-2008, 05:20 PM
4rx
4rx's Avatar
x2 unless if its rubbing, body lift would be a good idea. pm me if you have any question about the 3" body lift.
Old 03-11-2008, 06:16 PM
Question
Hey 4rx...my truck is not rubbing!!!! I only want to lift it more>!! i was concerned in the Center of Gravity ..because i have a 3" suspencion lift kit on it.!!...but in the future i will like to get 35" tires and like to have a sufficient room between the wheel and the body..
Old 03-11-2008, 06:28 PM
4rx
4rx's Avatar
I would imagine that suspension lift would be more concern in the center of gravity becuase its all weight on the frame and body. Its likely more sway. Don't quote on that cause I dont have suspension lift. any input would be great. body lift isn't much of issue with the center of gravity since stock suspension stay same ground clearance. 35's help more ground clearance. hope it helps.
Old 03-11-2008, 06:59 PM
Staff
DeathCougar's Avatar
I would stay away from a 3" body lift, especially in a 3rd gen. Amonng the problems you will encounter, getting the bumpers to match up and the shifter to operate correctly are big ones. You are also raising your center of gravity rather high, which means in evasive manuevers, its much more likely to roll.
Besides all that, 3" body lift leaves giant gaps between the frame and the body, and allows for a lot of body roll and body flex.
Old 03-11-2008, 07:00 PM
YZFr6-TX's Avatar
My 99 4runner now has a 3" body lift installed along with the 3" Revtek suspension lift. I love it. I was worried about the center of gravity, but it didn't effect the handling at all that I can notice. I am about to install some 1.5" alum. spacers by this weekend. I plan to replace the 33's with 35's, hopefully another set of MTR's.
Old 03-11-2008, 08:28 PM
4rx
4rx's Avatar
I ran 35's on without wheel spacers for a short time. I had to drive slowly. And then I installed 1.5" wheel spacers, it is much better and less roll stability. It's noticable difference!
cougar, to each their own, people are still doing install body lift on the vehicles. That's good for you if you are staying away from body lift. I respect that. Also it is easy homemade guards to cover the gaps.
Old 03-14-2008, 08:06 PM
hey yzfr6-tx...can you post some pics. showing the front bumper, general gaps, under chassis and the hole truck..please! I would like to see it!! thanks for the info about the BL.
Old 03-15-2008, 04:17 AM
Vermejo's Avatar
To fit 315’s:
1.5 BL
4 - 3.5 backspaced wheels
Minor wheel well trimming
Low profile control arms
To run 315's:
Re-gear
Tranny cooler
PS cooler
Consider Tundra brakes up front
This is how to run 35's with minimal negative impact on and off-road
Old 01-29-2009, 02:58 AM
chuckdeez's Avatar
does anyone have any idea about modifying t case shifter on 2000 4runner if a 3" body lift is done. my t case shifter has push button 2/4
Old 01-29-2009, 03:56 AM
Bighead's Avatar
I sent mine to Marlin Crawler to be modified.
Old 01-29-2009, 04:19 PM
chuckdeez's Avatar
i would like to modify it myself. i have all the equipment to do what needs to be done but would just like some idea of what ppl have in the past.
Old 01-30-2009, 09:28 AM
Conatus's Avatar
my 96 runner came with a 3" BL. I just left it in as I didnt want to mess with it. It did have a spacer lift so I ripped that out and installed a Sonoran Steel System 1.2 Suspension kit. It rocks. but it is ridiculously tall and even I at 6' have to literally jump into the seat. Girlfriend hates it.
If you read Steve Schaeffers site carefully you will see that he STRONGLY reccomends nothing over a 1.5" BL in combination with his system 1.2 and some mild trimming to fit 35's. He also says the only wheel that works without issue is the Mickey Thompson Classic II's. 3.5 backspace. Believe it. I have 4.5" backspace and though I dont rub the control arms I cant run spacers or the rubbing worsens.
The 3" BL isn't going to do anything for you other than make it look cool. I am seriously considering dumping mine for a 2" or even 1.5". Good luck!
Old 01-30-2009, 11:04 AM
chuckdeez's Avatar
well i'm going for more looks than anything right now wont on the trail too often. this truck is my daily driver so i was thinkin about putting toytec 3" and 2-3 inch 4crawler BL
Old 01-30-2009, 11:12 AM
4Runner202020's Avatar
i have 4 inches of suspension lift and a 2 inch body lift and i love the look and ride of it... it doesn't rub offroad with the 35's. pm me if you want info on my suspension..
bobby
Old 01-30-2009, 11:32 AM
4Crawler's Avatar
Post up some pictures of what the shifter and handle looks like. For example is the handle threaded or not, how do the wires for the shift route and attach to the handle, etc.
Some installation tips and photos on the pages below:
- http://www.4crawler.com/4x4/ForSale/...ft_HowTo.shtml
- http://www.4crawler.com/4x4/ForSale/...er/index.shtml
- http://web.archive.org/web/200504040...body-lift.html
Old 01-30-2009, 12:36 PM
chuckdeez's Avatar
okay i took some pics with my cell phone, looks like there is just a screw that hold is on, also seems like that in the haynes manual. i'm just pretty sure it will hit the console even if i extend it so was thinkin about a short shift or maybe re fab the shifter alltogether. the wires for the switch look like they unplug at a harness below the shifter boot although i am not positive on that.
Old 01-30-2009, 12:41 PM
4Crawler's Avatar
May be possible to extend/angle the shifter up from below (weld in an extension on the thin section below the boot. And angle it such that the front/back throw is centered in the console opening.
A short throw kit is not hard to do, would need to see if the shifter base needs a new spacer design or if an existing one would work:
- http://www.4crawler.com/4x4/ForSale/...shtml#Ordering
Other option is to raise the t-case and engine up:
- http://www.4crawler.com/4x4/ForSale/MotorMount.shtml
Old 01-30-2009, 01:06 PM
chuckdeez's Avatar
well i don't think i want to raise the engine/tranny.
i guess my only option is to put the 2 or 3 inch bl in and go from there. i'm confident with my metal fab skills and have the equipment to re fab the shifter myself. i guess noone knows for sure if any of the existing short shift kits will work? what info do you need to check if any of the existing ones would work?
Quick Reply: 3rd gen. 3" body lift help??
