3rd gen 285 spare tire?
Are any modifications needed to mount the spare tire underneath the rear for a 285/75R/16 tire on a 3rd gen 4Runner?
Originally Posted by lee
i have a similar Q... if i have 285/70/16 tires, can use a 265/70/16 spare? or is that ridiculous?
what if i have 265/75/16 tires and a 265/70/16 spare
Originally Posted by Darren
You can run one with no problem if you don't have a hitch receiver mounted.
If you do want a hitch receiver, the only one that I know of that works is the Hidden Hitch Class III, square tube style. It is part # 87511, which can be found on this page. OEM receivers will not work.
Running different diameter tires is never a good idea, especially for long distances. One problem is it can prematurely wear out a limited slip differential, with one wheel constantly turning faster than the other.
To get you off the trail and back home, heck yeah, you should be fine.
-S
Mine did not fit with the hitch until i got the 1.5" body lift. It fits fine now...It doesn't matter though, 'cause my Sonoran Steel rear bumper comes TOMORROW!
On the 265 spare with 285's...wouldn't that cause chaos with your traction control? Mine goes off if one of my tires has very low pressure...
Dozer
Dozer
when i went to 35's, i put a 285 under there for my spare, but i had to cut off my custon hitch to do it.... (super tight fit with the 265) but that didn't bother me too much, my new bumper has a hitch built in-
If you air down a 285 to about 12 PSI it will fit with a factory hitch, you just have to make sure when raising it into position, that you don't let it rest agains the panhard bar. This is how I have mine mounted.
06-01-2021 01:51 PM
FS[PacNorWest]: Factory Alloy Wheels - Bay area
94whiterunner
9
09-22-2015 07:28 PM
DrZero
18
07-24-2015 11:31 PM
skoti89
07-08-2015 12:05 AM
