33" tires on 2nd Gen 4Runners
Old 07-15-2004, 09:31 AM
Nodlew505's Avatar
Question 33" tires on 2nd Gen 4Runners
My 93 4Runner has a 2" body lift and I have added Downey HD springs and have Bilsteins all around. I just purchased some 33x12.50 Kumho MT--got them pretty cheap, run 1x at the "Brush Runs" in Crandon, WI. I am having them mounted on steel 15X8 Wheels and I will re-gear with 4.88 gears.
With this set-up, I don't anticipate any problems with the height, but I don't know about width, what back spacing do you recommend with this set-up? Anything else I should be considering at this time...I know lockers would be nice, but unfortunately not in the budget???
Thanks
Old 07-15-2004, 02:50 PM
Flamedx4's Avatar
Do your Downeys have any lift to them?
With about 3" total lift you should be able to run 33s, a bit more lift is good if you'll be havin' have lots of travel. You'll love the 4:88s.
Backspacing recommended 4 1/2", less will probably cause rubbing at full turn.
Old 07-15-2004, 03:43 PM
Cebby's Avatar
I've got BFG MT's on 15 x 8 MT Classic II's which are spec'd at 3 5/8 BS. They are actually a little over 3 3/4 BS when measured. I have a 1" BL and nothing else up front. Even with trimming and fender seam manipulation, I've got some rubbing. I'm adding the 1 1/2" Ball Joint spacer to help the cause.
Old 07-15-2004, 05:17 PM
NCSU-4runner's Avatar
tweak your torsion bars just a bit and you wont have any problems. I ran that exact setup for quite some time and had absolutly no rubbing, even in the front at full stuff and turn, i dont remeber what the backspacing on my wheels was.
Old 07-15-2004, 05:24 PM
Flygtenstein's Avatar
Just trim it a little and aim for 4" of BS.
I have about 1.5" of front lift on my 95 running 33" MT/R's on 15x8's.
Another Cheesehead, eh?
Old 07-15-2004, 06:39 PM
Dublin's Avatar
Hey Nodlew505, nice to see a fellow Crandon addict. Wondering if you attend the Antigo, Dresser, and Bark River CORR races as well. Anyways I've been running 33x12.5's for about a year now with a little inner fender and valance trimming. I still get a bit of rubbing especially cornering on uneven terrain, but the only real annoyance for me is the way the mud packs in around the wheel wells. Guess I need to seriously think about a lift.
Old 07-16-2004, 03:41 PM
Nodlew505's Avatar
Thanks for the input.
Thanks to all for the your advise and experiences. I will keep you posted when I get things thrown together.
Flygtenstein and Dublin--born and raised in the land o' cheese. Flygtenstein, nice flex in your rig by the looks of your avitar picture! Dublin I work in your neck of the woods, Neenah. This was my first experience at a CORR Race, my bro-in-law has been going for the last 2 yrs and trying to get me to check it out. It was awesome to not only see those guys run...or fly is the better word, but to get a chance to go in the pits and check out some of the rigs and set-ups. I am going to try to go to Antigo and will most likely hit Crandon again in the fall.
06-01-2021 01:51 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 33" tires on 2nd Gen 4Runners
