30k Service
Old 07-28-2005, 08:11 AM
2002 SportEdition's Avatar
30k Service
I plan to to the 30k service myself. i called the dealer and asked "if i can use all 6 NGK spark plugs or 3 NGK and 3 DENSO". they said it's OK to use all 6 NGK. What have you guys used?
(02 4Runner, sport 4wd...)
Thanks,
Old 07-28-2005, 09:46 AM
blackduck's Avatar
I just changed my spark plugs this weekend (30k mile service) with 6 denso plugs. The truck runs great.
Old 07-28-2005, 09:49 AM
95ToyotaPU007's Avatar
you can't go wrong with either.
Old 07-28-2005, 10:15 AM
2ToyGuy's Avatar
Let the Flames Begin!!
I use Bosch Platinum +4's. I only need to change then about every 100k, and I noticed a distinct improvement in performance when I first installed them. On the other hand, I hve 2 '87 22R engines, not one like yours, so...
Old 07-28-2005, 10:27 AM
KGnagey's Avatar
NGK all the way around. Mine had the same six to begin with and not 3 of each. MPG increased as well after the change.
Old 07-28-2005, 12:37 PM
rimpainter.com's Avatar
Always use the OEM plug on a stock 5VZFE. Be sure to gap it with a wire feeler-type gapper (Autozone has them) - this step is often overlooked.
Old 07-28-2005, 01:54 PM
montypower's Avatar
The stock plugs are the NGK with double "tips". They come pre-gapped. If you try to gap them, you'll likely damage them.
Old 07-28-2005, 02:11 PM
Not true. They say pre-gapped, but they are often gapped incorrectly. By using a wire feeler-type guage, you will avoid damaging the electrodes.
CPD4runner
9
11-05-2017 06:01 AM
Dale Johnston
11
10-31-2015 10:22 PM
Boomer8404
09-24-2015 01:12 PM
Boomer8404
09-20-2015 06:15 PM
4runnerstalls
09-17-2015 10:10 AM
Quick Reply: 30k Service
