305/70-16 vs 285/75-16 on a 3rd gen
#61
Originally Posted by bamachem
well, if you go w/ ats, then you run into other issues like overextending the CV joints on a full droop and then blowing them out. if you want to modify the upper a-arms, then do what steve schaefer did. there should be some good info on his site...
I meant: Since I already have ATS arms would I run into the rubbing issues and require the extra backspacing?
#62
If i run a wheel spacer with my stock rim will i run into trouble with a 305/70/16 given i have a proper lift? any recomendation on the size of the spacer thanks
#64
hes talking about on the a-arms.
andy has 16x8, 4.5 BS. you've got 16x7, stock BS, whatever that is. do the math to figure out what size space you need. check roger brown's site for wheel size math.
#65
but their should be no problem with the rim actually holding the tire right? Can you ever go too large with your spacer, i was thinking of just ordering a 2"
#67
on a 16x7 i would say to stick w/ a 285. it's a tight fit on a 7" wide wheel and it will rub w/o spacers or new upper a-arms.
a 305 is right at an inch wider, making them "bubble" out another 1/2" on either side of your 7" wide wheel.
they fit very nicely on a 8" wide wheel. the extra 1" makes a big difference.
LittleUgly
15
01-02-2020 01:30 PM
charlie_fong
09-27-2015 10:06 PM
