3.4L Timing Belt Issues - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-20-2006, 04:25 PM   #1 (permalink)
thefallman's Avatar
Send a message via MSN to thefallman
i have 3.4L that i am swaping into a 89 x cab. The issue is i got it from a Wrecking yard it was hit in the front end and broke the tensioner, so the wrecking yard cut the timing belt. they also turned the engine over and camshafts.
So i have No idea where the camshafts should be i set them to the timing marks but there is a possiblity of having the right bank 360degrees off from the Left bank so that the timing would be completly screwed any ideas on how to solve this???
thefallman is offline
Old 08-20-2006, 05:27 PM   #2 (permalink)
Send a message via AIM to Firefightertaco
This should help. http://www.4x4wire.com/toyota/maintenance/timing_belt/
__________________
JP
2003 Tacoma White TRD
E-Locker, 3" toytec lift, 2" RB BL 10,500 milemarker,
32/12.50 BFG MT on black wheels
UWS black toolbox, and working on more.
2007 fj cruser (moms)
86 4runner 22re auto 3" leafs 32bfg mts
Firefightertaco is offline
Old 08-20-2006, 06:43 PM   #3 (permalink)
MTL_4runner's Avatar
Send a message via AIM to MTL_4runner
Quote:
Originally Posted by Firefightertaco
If that doesn't get you back on track then this should be enough to put you over the top:
http://www.lieblweb.com/tacoma/Mecha...cans/index.htm
__________________
- Jamie
1996 4Runner SR5 4X4 Auto
Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift
Best OBD II scan tool I have used!.
.....and I am AMERICAN!
MTL_4runner is offline
Old 08-20-2006, 06:55 PM   #4 (permalink)
seanz0rz's Avatar
Send a message via AIM to seanz0rz Send a message via MSN to seanz0rz
wow, some great info there. that will really help when i do mine in another 70k miles
__________________
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Sonoran Steel #1, 285/75R16 BFG A/T, Elocker retrofit, Tundra calipers, brembo blanks, hawk lts pads, CarPC in custom center console with molded Indash touchscreen, KC daylighters mounted on Surco Safari rack, Custom sound system, 4xinnovation sliders, sleeping platform, Shrockworks front bumper, 1" 4crawler body lift, etc.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline
Old 08-20-2006, 10:03 PM   #5 (permalink)
thefallman's Avatar
Okay so i feel like a complete idiot now. After i read those 2 links i realized something it is imposible for the cams to be out of alignment by 360 degrees because they rotate at half the speed of the crank so for every 2 revolutions of the crank they rotate once so they could be 180 degrees out but not 360. and if they were 180 out you would know because the timing marks wouldnt line up. they would be 180 degrees off on the cams only. so if you line up the timing marks your all good
Tags
1998, 34, 34l, 4runner, belt, dohc, liter, marks, pics, pictures, replacement, tacoma, timing, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
timing belt issues budro 86-95 Trucks & 4Runners 3 05-19-2007 05:12 PM
@#$#@ Timing Belt install (3.4L) quattro 95.5-2004 Tacomas & 96-2002 4Runners 15 07-05-2006 05:01 AM
Post timing belt issues?! mtrdrms 86-95 Trucks & 4Runners 5 06-21-2006 04:42 AM
3.4L timing belt idlers Mickdady 95.5-2004 Tacomas & 96-2002 4Runners 9 03-22-2005 04:20 PM
Timing belt replacement: 3.4L AJatx 95.5-2004 Tacomas & 96-2002 4Runners 28 10-14-2004 09:28 PM
2009 InternetBrands, Inc.
