3.4L swap
Old 06-10-2003, 11:08 PM
jasonb's Avatar
3.4L swap
I posted about a week ago that I was having problems with my 3.0L. I did a compression check and the #6 cylinder was at 30psi.
I am going to do a swap to the 3.4L. I have checked around and am not finding much info. Do any of you guys know of any sites that have good info on this? Thanks!
Old 06-11-2003, 04:54 AM
Highland Runner's Avatar
Check out http://www.pirate4x4.com/forum/showt....0+to+3.4+swap
Old 06-11-2003, 07:58 AM
Cebby's Avatar
This one is into a 2nd Gen. I think there are additional hood clearance issues on the 1st Gens.
Old 06-11-2003, 08:48 AM
its2slo's Avatar
isnt 89 a second gen?
Old 06-11-2003, 09:05 AM
Cebby's Avatar
I thought 2nd Gens started in 90. I've been wrong before...
Old 06-11-2003, 01:01 PM
jasonb's Avatar
1990 was the first year for the 2nd generation 4Runners. I have an 89 4runner and it is a 1st generation. The trucks started the 3rd generation in 89...a year earlier than the 4runner body change.
Old 06-11-2003, 03:44 PM
its2slo's Avatar
thanks, i never knew that.
Old 06-11-2003, 05:43 PM
Victor's Avatar
Hood height should be similar between a 1st and 2nd gen. I think the article with the 3.4 swap into a 1st gen required a hood cutout because the guy didn't have a body lift. I've heard 1" body lift is mandatory and others say 2". Only complete one I know of has a 2" body lift.
Old 06-11-2003, 10:28 PM
jasonb's Avatar
I have a 1" body lift on mine...so we'll see if it works. If it doesn't, I'm debating on whether to go to a 2" body lift or just add a hood scoop.
Old 06-12-2003, 06:38 AM
1Runner's Avatar
Your record of one error EVER is still intact Cebby. Make sure you inform your wife
Old 06-12-2003, 11:22 AM
Cebby's Avatar
My ears still ring from the whack across the head with the frying pan - from the last time I "reminded" her that I'm always right...
What was the one error? I've erased it from my memory obviously.
mussy01
12-13-2016 08:20 PM
1996Taco
07-20-2015 12:02 AM
taller1
07-16-2015 03:00 PM
Seattle_Sign_Guy
07-12-2015 12:38 PM
Quick Reply: 3.4L swap
