3.4L Radiator Flush
Old 01-18-2005, 01:02 PM
4Runner4Christ's Avatar
3.4L Radiator Flush
I have searched through the forums, my owners manual, and the write-up section but did not find answers to a few questions (although I did see stuff on the 3.0/22RE, etc). A flush isnt a big deal, but I have a few questions (please only post info if it pertains to the 3.4L):
1. Is there only one drain plug (the one on the radiator)?
2. To drain the fluid do you turn the valve counterclockwise? (I have had radiators where you turned then clockwise to drain, and I dont want to break off another drain plug).
Everything else I am OK with. Thanks
Old 01-18-2005, 01:06 PM
Mickdady's Avatar
1. Some manuals say 2 (1 on block, 1 on rad), many people have searched to find the second one, I haven't seen it. Just use the Rad drain it works just fine.
2.lefty loosey
Don't forget to use distilled water.
Old 01-18-2005, 01:12 PM
bulldog-yota's Avatar
What do you guys do with the old fluid?
Old 01-18-2005, 01:17 PM
Mickdady's Avatar
I take mine to the dump which has a fluid recycling center. If yours doesn't have that shucks and some autozones will take it.
Old 01-18-2005, 01:19 PM
HaveBlue's Avatar
Pour it down the nearest culvert.
Just kidding.
Here in Colorado, there's a place where we can take household chemicals, coolant included, to dispose of them. They charge $10, but there's no limit.
Check your yellow pages for waste disposal. Your own trash company should even have a contact/place for you to go.
Old 01-18-2005, 01:37 PM
Thanx, will keep it in mind next time I need to have it flushed. Tired of paying dealer to do it.
Old 01-18-2005, 03:41 PM
99runner4me's Avatar
I just flushed mine Friday night, and only found 1 drain plug.
Just flush your old fluid down the toilet as long as it's not oily.
Old 01-18-2005, 05:01 PM
Mikey's Avatar
I found this site along time ago when I was trying to get rid of some old oils and stuff. It's pretty good. Just type in you zip code and it will tell you who's local that will take the stuff.
http://www.earth911.org/master.asp
Old 01-18-2005, 05:15 PM
r0cky's Avatar
you could always change the fluid like i did - have some guy come over to work on your truck and maybe one of the times you have your back turned he'll saw into the radiator and all the fluid will drain out down the driveway. to avoid people asking who was murdered in your driveway, put down kitty litter to absorb it.
just kidding - i definitely don't recommend that method, as i continue to experience issues with it leaking.
try the site Mikey recommended.
Old 01-18-2005, 06:59 PM
Thanx for the site, will look into it for next time.
I dont think it is a good idea to flush it down the toilet, antifreeze is toxic who knows where it ends up.
And I prefer to use the flush valve to holes in my radiator
Old 01-18-2005, 07:23 PM
r0cky's Avatar
gee, i don't know why you'd prefer that!
Old 01-19-2005, 06:32 AM
Thanks for the info everyone. I ran into a little snag...I realized that the skid plate needs to come off to get at that drain plug easier...and I have a skid plate bolt that is rounded off...
Old 01-19-2005, 07:41 AM
Mickdady's Avatar
I had one rounded too. If you reach through the passenger side lower wheel well you can reach the petcock. I put a small piece of cardboard in the front bolt hole to deflect the coolant straigt down while it was draining. It worked pretty well and only a little spilled down the skid plate.
Old 01-19-2005, 07:46 AM
Amir904's Avatar
what are the consequences of NOT using distilled water?
Old 01-19-2005, 08:10 AM
Mickdady's Avatar
The impurities in tap water contribute to corrosion. I also put a bottle of water wetter in my radiator. I use it on all my vehicles including my 2-stroke dirtbike.
Old 01-19-2005, 08:12 AM
Mickdady's Avatar
I should also mention, if you used tap water....don't worry to much. The dealerships use tap water when they flush too. Distilled just seems to do a better job of keeping the cooling system clean. If you do regular flushes you will be ok.
Old 01-19-2005, 08:28 AM
Robinhood150's Avatar
Some areas do legally allow you to pour it down the toilet, it depends on whether the sanitation place down the line can accept it. Check your local laws...
Old 01-19-2005, 12:27 PM
Interesting, I'll try to get at it that way. I have a section of bicycle tire innertube I am going to put around the petcock and point down thru the opening to the catch pail. That should accomplish the same thing.
Longbed 90
03-11-2019 12:38 PM
LotOMiles
09-14-2015 11:45 PM
noahstancik
09-10-2015 10:47 AM
Squigglez
09-04-2015 07:33 AM
128keaton
09-03-2015 05:09 PM
Quick Reply: 3.4L Radiator Flush
