3.4L Cam specs needed.
I have been looking for the stock cam specs for the 5VZ-FE. If anyone has them I would gladly pay you for the info or buy you a .
I need lift, duration and degrees. All the standard info so I can mess with the overlap and timeing. Im installing my new valve springs and retainers. So, cam overlap and timing will be critical to extracting more power when I move the redline up.
jmpersek@bulldog.unca.edu
I would ask to speak to an engineer about that, I am sure they can help you out.
kawazx636
07-03-2023 03:03 AM
FS[PacNorWest]: 1987 4Runner SAS, 22RE, 5Spd, Dual Cases, etc
toyotasaurus
09-24-2015 03:30 PM
joeynational
09-05-2015 01:54 PM
