3.4L 4Runner Brakes
3.4L 4Runner Brakes
I recently went to the stealership to have my rear shocks installed and have my front brakes checked because they squeal something awful.
I removed the tires and checked the rotors and pads and there is plent of rotor and pad. The brakes work fine though every now and then they seem to grab a little more.
Anyhow I was told that my rotors need to be turned (which is what they always say) and the pads need to be replaced.
I was told that they are glazed (whatever that means).
How do brakes get glazed? What does the glaze look like?
Your assistance is greatly appreciated!
- Frederick
Glazing is caused from excessive heat on the rotors. Its essentially a foreign "film" that is now bonded to the rotor, significantly reducing brake performance and often inducing squeal.
I'm not a fan of riding the brakes and driving very moderately.
After I took it to the dealership It didn't squeal for about 2 days then it was back again.
I ordered the TRD HP Pads and planned on letting them turn the rotors I just don't want to end up back where I started after all the added expense.
Is turning the rotors the only way to get the glazing off?
Is there anything else I should look for on the rotors, pads, etc... ?
I'll be taking the tires off again soon and thought I would ask.
I had a friend of mine tell me that a cheap trick for resurfacing rotors was to just sand it yourself. 80 grit sandpaper with a power sander and just make your own swilrs.
I'm not convinced though. Seems a bit shady...
Re: TRD Pads
Originally posted by TOR
Save yourself some money next time and just order the regular pads, there isn't much difference except in price.
Todd
Todd
TRD Parts
Well I am an honest parts man and we barely make .2 to the dollar on the TRD parts. As for my manager he knows the way we roll here, he heads it up!
Todd
Todd
What year is your rig? How many miles? Mine is a 99 and I remember a TSB issued in Dec 2000 concerning brake vibration on the 3rd gens. I talked to Toyota corporate and they set me up with Arlington Toyota of Jacksonville to have the brakes inspected. My steering wheel used to vibrate/shake when braking at 35-45 mph. They found the fronts and rears warped due to the uneven braking. They wanted to just resurface it but I insisted in getting it replaced. They adjusted the front and rear bias and also replaced the rotors/pads and drums/shoes. So far no vibration at all eversince. Check this out. Hope this helps.
george
george
Re: 3.4L 4Runner Brakes
- Frederick
- Frederick
Does turning rotors make sense if they are $25 a pop brand new? Just seems like the labor is so much greater than the little extra for brand new rotors, might as well get new ones.
Originally posted by <96 Runner>
Something else to have the dealer check is the LPV. The Load Proportioning Valve decides how much rear braking is needed based on load. If that gets out of whack, or the rear brakes are in need of adjustment, the front brakes could be getting too hot because they are doing most of the work (more than normal).
Hmm, I remember surfing the web before even getting the 4Runner and found plain jane rotors for 25.99 or 26.99. Autozone probably has them pretty cheap too.
In my experiance rotors warped when they were well worn, so replacing them is more economical than doing it again in the future.
i use 100 gritt on my downhill mtn bikes rotors and then use alchole(sp?) on it and dont touch them.
on the pads start in the center and pull away towards the edge of the pads. hopethis helps
Are you guys just rambling or what? Autzone had Brembo OEM replacement for under $50 too. Autozone is hardly a store selling 2nd rate parts, and prices to challenge mail order too!
