3.4 swap
Old 10-19-2005, 03:58 PM
Manson's Avatar
3.4 swap
I will be doing a 3.4 swap in my 94 runner. I read you can use the 3.0 flywheel on the 3.4. Is this correct? If so couldn't you use the 3.0 clutch. If you have to use the 3.4 flywheel I am assuming you can just use the 3.4 clutch unless the disk splines are different from one to the other.
Old 10-19-2005, 04:58 PM
Bob_98SR5's Avatar
not sure about your specific question, but have you searched your thread title "3.4 swap?" i do know taht there are a number of very long threads about the 3.0 to 3.4 engine swap.
bob
Old 10-19-2005, 08:24 PM
Manson's Avatar
I have searched and read all posts pertaining to this swap. That is where I read you could use a 3.0 flywheel on a 3.4. I was wondering if this was true.
Old 10-20-2005, 11:45 AM
Pozi's Avatar
I am currently doing this conversion myself. From what I understand you use the 3.4 flywheel and clutch disc/plate and the 3.0 TO bearing. Sucks because the 3.4 clutch is much more expensive then the 3.0.
Old 10-20-2005, 07:44 PM
Willcipher's Avatar
I believe you'll have to use the 3.4 flywheel, clutch disc and plate from the 3.4. I don't remember specifically comparing them but I think the bolt pattern and spacing is slightly different; not to mention the disc is larger. One thing for sure, you must use the 3.0 release bearing; I just put another 3.4 in my 88 4runner (I melted pistons in my original 3.4 ) and the 3.4 clutch kit includes a release bearing that won't work with the 3.0 transmission.
Flying91
45
04-11-2024 04:39 PM
LosPatosDelSur
23
03-12-2021 03:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
93toyoguy
08-02-2015 07:41 PM
94whiterunner
07-12-2015 07:15 PM
Quick Reply: 3.4 swap
