3.4 Manual Trans Water pump
Old 03-02-2014, 01:01 PM
blue1's Avatar
I'm getting ready to do my timing/water pump etc. Do I need the water pump with the outlet tube or without it? Doesn't it go to the transmission cooler--which I don't have?
Old 03-02-2014, 01:29 PM
sr5lifestyle's Avatar
I planning to do my timing belt in the next 2 weeks. I believe the outlet tube you are referring to goes to the engine oil cooler mounted on the drivers side of the engine block. Those with automatic transmissions has the trans cooler connections on the bottom of the radiator.
TheDurk's Avatar
No, it goes to an engine oil cooler on the block. The auto transmission fluid cooler is inside the radiator.
My 5-speed has the outlet tube on the WP. You should be able to see the cooler about two feet to the rear of the oil filter on the driver's side of the block. Look from underneath. It looks like this:
Old 03-02-2014, 01:46 PM
blue1's Avatar
Great --thanks
09-04-2015 09:27 AM
thefishguy77
07-30-2015 10:59 AM
KBar
07-13-2015 06:01 PM
Jonny246
07-12-2015 04:51 AM
cars-guy
07-11-2015 07:51 PM
Quick Reply: 3.4 Manual Trans Water pump
