3.4 liter v6 tacoma spark plug gap sparkplug question - YotaTech Forums
Go Back   >
LinkBack Thread Tools Search this Thread
Old 07-26-2006, 11:48 AM   #1
kwikrnu's Avatar
My new / used truck was missing at wot and pinging a bit. It is a stock 3.4l v-6 95.5 tacoma. I decided to check the plugs and change out the fuel filter.
A trip to Autozone and $25 later I had six cheapo bosch super plugs # 7557 and a private label filter # FF692 I was on my way.
Autozone said I should gap the plugs at 0.032. I did that with a jacobs gap pliers and double checked with a small wire gauge.
I removed the old plugs which looked well worn gap was 0.065(no wonder the truc was missing-Stock ignition system can't be good enough to bridge that gap consistantly at WOT). I guess they have been in there for at least 100k miles. One was a stock plug someone had probably forgotten to change.
Fuel filter was full of crap / rust on the tank side.
Truck runs much better at WOT and no pinging.
Maybe I should have used the ngk dual ground strap but the truck has 215k miles and those plugs cost more.
On side note it passed emmisions this morning with okay #'s with the original parts.
kwikrnu is offline   Reply With Quote
Old 07-26-2006, 01:50 PM   #2
mt_goat's Avatar
I think the FSM calls for .043 gap for your truck doesn't it?
mt_goat is offline   Reply With Quote
Old 07-26-2006, 02:24 PM   #3
kwikrnu's Avatar
That is why I posted. I do not have a FSM. The guy from AutoZone said the gap was .032 and that is such a huge difference between what was on there .065. The interesting thing is the solo nkg plug dual electrode had about a .045 gap.
I wonder if a dual electrode is recommended because the heat may actually bend the ground on regular plugs over time extending the gap.
I did a search and saw most people would do the gap larger than .032...
I figured my gas mileage will go way down if the gap is too small due to the small spark not igniting the entire fuel air mix.
Old 07-26-2006, 03:08 PM   #4
Mickdady's Avatar
The dual electrode is used because of the spark waste ignition system used on your vehicle. Basically, as I remember the spark plug fires on the power stroke as well as when the opposing cylinder fires. This way the ignition system manages 3 cycles instead of 6. Someone correct me on this if I am wrong. My memory is not so good.
anyway, the reason for the dual electrode is over the standard maintence period that plug will fire 2 times as often as if it used standard ignition timing. A standard plug will wear much quicker in this circumstance.
Mickdady is offline   Reply With Quote
Old 07-26-2006, 07:33 PM   #5
Elton's Avatar
ya factory plugs are a little pricey i paid about $20 dollars for 6 but i will not buy anything but ngk or denso
Elton is offline   Reply With Quote
Old 08-01-2006, 05:34 PM   #6
This engine requires dual electrode plugs no questions asked. The FSM says so and the picture on the engine reminds you. Why doubt it, really?
Mike.
vudbster is offline   Reply With Quote
Redeth's Overland Trailer Build Redeth005 The Fab Shop 92 07-23-2016 10:56 PM
Noob help. Is the 3vze that bad? To keep or sell '90 pickup 3vze 4x4, 160k, manual primordialbeast117 86-95 Trucks & 4Runners 11 12-19-2015 01:23 PM
please help me! Problem opening trans case G52 hiluxinargentina 86-95 Trucks & 4Runners 3 09-30-2015 06:51 PM
3.4 and automatic for heavy towing toyhaulert100 Newbie Tech Section 3 09-24-2015 08:55 PM
toytec lift question Dparr2ndgen 95.5-2004 Tacomas & 96-2002 4Runners 0 09-08-2015 02:06 PM
Tags
2002, 2003, 34, 5vzfe, denso, gap, plug, plugs, spark, sparkplug, tacoma, tocoma, torque, toyota, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
2010 InternetBrands, Inc.
