Sign in using an external account
| 95.5-2004 Tacomas & 96-2002 4Runners 4th gen pickups and 3rd gen 4Runners |
| Welcome to Yotatech! |
LinkBack | Thread Tools | Search this Thread |
#1 (permalink) | ||||
Personal
Sales Rating: (0)
3.4 L V6 Cooling issues at high RPM
#2 (permalink) |
Personal
Sales Rating: (0)
The radiator may still have corrosion in it that the cleaner is not removing. Radiator is full and you have gotten all the air pockets out of the cooling system i.e. burped it?
Right before I did my last timing belt change (80k after prior one), I was running at 203 deg around town. When I pulled it apart the pulley on the water pump was caked in burnt rubber......hmmm. My guess is that the hydraulic tensioner was failing allowing the timing belt to get some play and begin slipping as it went over the water pump. The water pump looked ok. After replacing the water pump and everything else in this kit, my temp dropped to 191 deg around town. http://www.ebay.com/itm/Toyota-TIMIN...item2a144a37e8 The jiggle valve should have no impact once the thermostat is open.
__________________
95.5 Tacoma 3.4L Auto FSMs TSBs P/N & diagrams (source for OEM on east coast) PNW OEM Parts source - Titus-Will, Tacoma, WA Last edited by rworegon; 01-17-2012 at 06:00 PM. |
#3 (permalink) |
Personal
Sales Rating: (0)
[OP]
I have gotten all the air out as far as I know.
I did the timing belt and bearings from napa at 135,000, but have always gone with the "if it aint broke don't fix it mind set". I don't have access where I am at to a reader, but before I did any of the list of cooling things to it, it was 180 after a long overheating drive and sitting for 5 or 10 minutes before reading it.... That is the kit I am looking at buying, but am a little short on funds to just start throwing money at things that may or may not fix my problem. I was hoping the fan clutch and thermostat was the issue. Probably should have bought the OEM thermostat, but got what I could at the time. Thanks for the info. |
#4 (permalink) |
Personal
Sales Rating: (0)
What's your indication it's overheating? The needle a bit too high?
For $20 or so you can get a T-stat from the dealer....it's a 82C or 180 deg F. Normal operating range is 176-203F per the FSM so 180 a few minutes after stopping is not unreasonable...sounds pretty normal really.
__________________
95.5 Tacoma 3.4L Auto FSMs TSBs P/N & diagrams (source for OEM on east coast) PNW OEM Parts source - Titus-Will, Tacoma, WA Last edited by rworegon; 01-17-2012 at 06:32 PM. |
#5 (permalink) |
Personal
Sales Rating: (0)
[OP]
Yes, the needle is a bit to high, and seems to be functioning properly. I had a long drive that caused it to climb higher. Like I said, that was at high speeds/rpms, and the needle had already dropped to normal after driving through town and shutting it down before I got the reader on it.
Realized the fan clutch was bad at that point, and didn't have access to the reader after I replaced that and the T stat. It is kind of hit and miss when it really gets hot. After I replaced those things, I drove it for some distance and tried to make it get hot, but wouldn't. I am litterally pulling hairs out because it makes no sense to me, or any of the mechanics I know. Again, thank you for your input. |
#6 (permalink) |
Personal
Sales Rating: (0)
Any chance that it might be starving for fuel from a clogged fuel filter?.... Maybe causing a lean mixture during times of high demand resulting in pre-ignition and overheating? Any pinging?
#7 (permalink) |
Personal
Sales Rating: (0)
[OP]
Haven't noticed any pinging, but I am quite handicapped in that are. The cooling issue did start after my trip to Mexico for Thanksgiving... Could have got some dirty fuel down there. I will try to get that changed tomorrow and see if that makes a difference.
Thanks for the input, I will report back as soon as the fuel filter is changed. |
#8 (permalink) |
Personal
Sales Rating: (0)
[OP]
Well, fuel filter changed and that didn't change the problem one bit.
I am at the point that I just need it fixed, and that might mean a whole cooling system rebuild and hope that fixes the issue. Anyone have any other ideas? |
#9 (permalink) |
Personal
Sales Rating: (0)
I would think its the water pump. Or maybe the timing belt tensioner is shot and the belt is slipping on water pump?
#10 (permalink) |
Personal
Sales Rating: (0)
[OP]
Update.
Replaced the tensioner, but didn't have the resources to get the timing belt and water pump changed. Still overheating, gonna have to nurse it home where I have the right tools to replace the timing belt and water pump. Gonna go ahead and have the radiator rotted out since I have an uncle with a radiator shop, just to make sure it isn't a blockage in there causing low flow. Thanks for all the suggestions. |
#11 (permalink) |
Personal
Sales Rating: (0)
Checked radiator hoses? Could collapse under higher pressure at high rpms.
#12 (permalink) |
Personal
Sales Rating: (0)
Clogger radiator fins. Try power washing the front and back side to get out anything stopping the air flow though it. For $120, it might be a good time to replace the whole radiator.
My guess is that once you get to speed the air flow is insufficient to cool the engine. Then there is always a head gasket issue. Is the coolant blowing out of the overflow tank? |
#13 (permalink) | |
Personal
Sales Rating: (0)
That is a good point. The return hose (lower hose) can be under a bit of suction. One cheap aftermarket lower hose I bought at Pepboys once came with a big metal coil inside. They said it was to prevent the hose from collapsing from suction.
__________________
93 4X4 ext-cab, auto, SR5, 3.4 V6, supercharged, 2.1" pulley, URD fuel mods, Aquamist WI, IPT valve body mod, dual cases, 4" superlift front, Alcan springs rear, 33 BFG KM2, ARB locked front & rear, 5.29 US Gears, RB 1" Body Lift, TJM T-17, Warn m8000. Quote:
#14 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks for all the help guys.
Ended up replacing timing belt, tensioner, pullies, water pump, hoses, radiator and even changed the oil. PROBLEMS FIXED!!!!!!!!! :-) On the last road trip, I noticed some wierd wear on my tires. Pretty sure I have a front driver side wheel bearing going out. :-( Anyone know what that usually costs to have done? If not, I am sure a little searching should turn up the answer. Thanks again, LTC |
#15 (permalink) |
Personal
Sales Rating: (0)
Nice! Glad you got it fixed. Now you'll be good for another 90,000 miles.
![]() How did the water pump look? Were any of the pulleys coated in rubber like I experienced (post 2)?
__________________
95.5 Tacoma 3.4L Auto FSMs TSBs P/N & diagrams (source for OEM on east coast) PNW OEM Parts source - Titus-Will, Tacoma, WA |
#16 (permalink) |
Personal
Sales Rating: (0)
[OP]
Water pump was still in great condition (spare parts for an emergency?), and none of the pullyes had rubber build up on them. The old tensioner was good, according to the Haynes manual test that is.
I am pretty sure it ended up being a clogged radiator. Instead of having a free rot out on it and giving it a go, I oppted for a new one at 150 bucks through autozone because they had one in stock with a lifetime warranty, and I needed one within a days notice. LTC |
#17 (permalink) | |
Personal
Sales Rating: (0)
Quote:
Also inspect the ball joints when you pull the spindle off. FOG
__________________
2001 4runner SR5 - ARB Bull Bumper, Warn 9.5XP, GM CS-144 150 amp alternator, Tundra brakes, OME 883/891s, SS adjustable traction bar, B&M 70264, and too many ham radios and antennas. 2006 Jeep LJ - Stock down to the lug nuts |
#18 (permalink) |
Personal
Sales Rating: (0)
[OP]
Thanks FogRunner, I replaced the lower ball joints not too long ago, along with the CV axles, rack and pinion bushings, and inner tie rod joint (the one located on the inside of the boot on the rack and pinion assembley).
The bearings seemed fine then, but I am not exactly easy on my truck, and that was quite a few miles back (I guess I forgot to write that down, oops). Doesn't really matter to me because this truck will die with me and I will replace what I have to inorder to keep it running while I can afford it.... LTC |
| Tags |
| 34, 34l, belt, cooler, gm, high, hose, hydraulic, issues, jiggle, oil, position, return, rpm, tensioner, timing, v6, valve |
