| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
3.4 to 2.7 motor swap questions...
#2 (permalink) |
I can answer the 1st part, V6 and I4 equipped Tacomas and 4Runners used different manual trannies, the 2.7 would have the W59, while the 3.4 would have the R151F. From everything I have read the R151F is considerably stronger than the W59. I believe swapping a R151 for W59 has been done, so I imagine with some sort of adapter you could make it work.
#3 (permalink) |
R151f is a turbo transmission from the 22rte trucks and 4runners.
Transmissions are NOT the same. you will also need to move the mounts on the frame. change wiring, ECU, and all the things like cruise, evap...honestly it would be more worth it to put the 3rz in an older pickup or runner. See build in sig
__________________
87 longbed, 3rz, tacoma dash, bobbed, SAS'ed, gears and more. My build----HERE More web wheeling- Just getting started so come join us Asphaltsux |
#4 (permalink) |
keep the 3.4 in it, sell the 2.7 and get newer 3.4....
motor mounts are different, wiring is a lot different.... lots of work to swap in the 3.4 for the 2.7
__________________
97 4runner, 2.7 5speed 4wd, 5.29, 33 horns armor locked lifted heavy SOB broken front and rear swaybars My Profile.. |
#5 (permalink) |
"You aint got to down grade, you can get what I get"... i.e 3.4L to 2.7L (Rap song)
__________________
99' SR5 3.4L Auto 4x4, Tokico shocks, Michelin X' terrains 265-70-16's, True Flow, M1 Extended preformance oil & filter.... BTW 99' 4 runner's are "factory" lifted..(hehe) |
