3.0 Radiator swap into 22-RE can it be done?
Old 11-07-2005, 11:16 AM
Extremesolo's Avatar
Question 3.0 Radiator swap into 22-RE can it be done?
I have a 87 runner with the 22-RE and I need a new radiator. I have access to a 3.0 (from an 88 runner) that is being parted out. Will the radiator from the 3.0 fit into my 22-RE and what hoses will I need to use to connect everything? The water pump went out and I found this problem as well. I would like to get it back on the road as soon as possible which is why I am tryng to do this swap. are there any major differences between the two? I haven't even looked at the new radiator yet which is why I am asking so many questions. Thanks for any help.
Last edited by Extremesolo; 11-07-2005 at 11:18 AM. Reason: forgot to add donor year
Old 11-07-2005, 04:54 PM
superjoe83's Avatar
I'm pretty sure that it is a direct swap, the only difference is that the 4cyl rad is a 2-row vs. the 6cyl 3-row
Old 11-08-2005, 04:38 AM
TTT
Anyone else with more info? I know someone has done this before.
Old 11-08-2005, 05:12 AM
dwh91102's Avatar
you are correct sir
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
tobylab
01-18-2016 07:06 PM
Alex Bessinger
08-31-2015 09:17 AM
tobylab
07-12-2015 12:53 PM
Coreyr384
07-10-2015 11:13 AM
Quick Reply: 3.0 Radiator swap into 22-RE can it be done?
