3.0: how to remove PS pulley from pump?
Old 03-06-2004, 10:34 AM
hellas's Avatar
the manual says theres a woodruf key, but im not sure how to take it out. how is the key supposed to release?
thanks
Old 03-06-2004, 10:44 AM
WATRD's Avatar
thanks
A Woodruff Key is a captured key that is set into a notch in the shaft, then the pulley has a groove that slides over the key, tying it all together. You can see an example in this photo;
http://www.difflock.com/servicing/30...y-&-Modifi.jpg
The key sets into a normally semi-circular notch machined into the shaft and looks like this; http://www.difflock.com/servicing/30...odruff-Key.jpg
Woodruff keys don't "release" as such. They are only there to align the pulley on the shaft and to keep the pulley from spinning on the shaft.
You should be able to use a pulley puller to remove the pulley, then you will see the key set in a notch or groove in the shaft, as well as the matching groove in the pulley.
I hope that helps.
Old 03-06-2004, 11:38 AM
If there like the 22RE P/S pumps, after you get the nut and washer off the pully should slide off with a little wiggling, mine did.
Keep track of the key, I put mine in a ziplock bag with the nut, washer and pulley.
John
Doug4320
03-24-2018 10:11 PM
09-04-2015 09:27 AM
yoterr
07-24-2015 04:29 AM
jjrbus
07-19-2015 02:06 PM
dinks07
07-15-2015 05:34 PM
Quick Reply: 3.0: how to remove PS pulley from pump?
