3.0 to 3.4 swap air intake
Old 05-08-2006, 06:05 PM
halcyon0's Avatar
This is a question to all those out there that have done the 3.0 to 3.4 swap. Can I use the stock 3.4 air intake system? Will it fit, or do I have to get an after market system like the K&N fipk air intake?
Thanks!
Old 05-08-2006, 06:57 PM
914runner's Avatar
You can use it, but you have to cut off the stock mounts molded to the airbox and drill holes through the bottom and bolt it to the inner fender.
Old 05-09-2006, 09:51 AM
halcyon0's Avatar
Thanks!
Thanks for the info! I guess I will have to look at it and line everything up. Thanks!
Old 05-09-2006, 04:17 PM
914runner's Avatar
I would have pics, but I lost a hard drive and when I had the data recovered, I didnt get it all. So I lost a BUNCH of my swap pics.
Old 05-10-2006, 05:57 AM
mt_goat's Avatar
I've halfway fit mine in. So far I've only had to cut off the front brace that goes over the washer bottle. I did have to cut away part of the old battery tray to let the airbox sit more level. I plan on fabbing up a new brace to replace the one I cut off, maybe going over the washer bottle. I going to wait until the engine is in to do the final fitting. I am planning on cutting an extra hole in the front of the airbox and a hole in the inter-fender where the original inlet is. I'll eventually get some pics together of it.
Old 05-10-2006, 08:24 AM
halcyon0's Avatar
Pics!
I would love some pics if you could get them! Thanks!
Old 05-10-2006, 09:43 AM
mt_goat's Avatar
It looks like I'll be able to use the two bottom mounting points, so don't cut them off unless you have to.
Charecter1
11-06-2023 10:08 AM
toyotamonster
3.4 Swaps
7
04-16-2020 06:02 PM
steve miller
10-10-2015 01:40 AM
coryc85
09-09-2015 06:24 AM
jon.r
07-11-2015 03:34 PM
Quick Reply: 3.0 to 3.4 swap air intake
