2wd 7.5 vs IFS 7.5 fitment non-Taco
Old 10-23-2005, 02:21 PM
JamesD's Avatar
Will these gears swap? The reason why I ask is because I have a 7.5 4.56 Precision Gear with a limited slip and I would like to use it in the front. Is it possible? I mean just the guts not the carrier.
James
Old 10-23-2005, 07:54 PM
kyle_22r's Avatar
yep. however, the rear 7.5 uses a third member and the carrier bolts into the axle housing on the front like a dana axle, so you'd need to re-set the gears to swap them over.
Old 10-23-2005, 07:56 PM
JamesD's Avatar
Yeah I dont care about that. I knew that has to be done. Will the limited slip fit as well? I may be getting gears from a member here which would be 4.88's. I will sell the 4.56's if all is well.
James
Old 10-24-2005, 09:00 PM
kyle_22r's Avatar
carriers are the same, only thing different is the housing(how they're mounted). should be swappable one to the other.
TheBFA
02-15-2020 06:55 AM
Thamuel_
Domestic Swaps
10-03-2015 11:15 AM
dirk89
10-01-2015 05:15 PM
JookUpVandetti
09-30-2015 08:58 AM
Cycles
09-29-2015 06:37 AM
Quick Reply: 2wd 7.5 vs IFS 7.5 fitment non-Taco
