2wd to 4wd
Old 02-11-2009, 01:18 PM
92yotaman's Avatar
2wd to 4wd
Ok, im in the market for an 02 tacoma and i don't have too much cash so i was thinking, if im going to SAS this and put dual cases, and im low on money... then why don't i buy a 2wd truck and build it up. SOO how hard is it to convert a 2wd to a 4wd with a solid front axle? I know it has been done, and i know i can save a ton of money just buying a 2wd truck. Inputs please.
P.S. how wide is the elocker rear end, hub to hub, in an 02 taco?
Old 02-11-2009, 01:37 PM
rdlsz24's Avatar
How much can you save by buying 2wd? Imo it wouldn't be worth it to convert.
Rob
Old 02-11-2009, 03:56 PM
92yotaman's Avatar
well ive seen 2wd tacomas for half the price of that same in 4wd, but i figured if im changing all this stuff out anyways why not try it
Old 02-11-2009, 04:04 PM
scuba's Avatar
when you say your changing out all this other stuff whats that mean? second: if your actually going to do that, calculate in id say 2k for all the parts, your gonna need a new tranny from a 4x4 with the t case, not to mention the 2wd suspension is different from 4. um, if your gonna do it, most other peóple have just done an sas in the process and gottén rid of the ifs. cell phone at work ftl, if that seemed jumbled
Old 02-11-2009, 04:16 PM
92yotaman's Avatar
ok here's what all i mean. i know id have to find a new tranny, and id be doing dual cases most likely, 63in chevies in back, and a SAS up front. So even if i did get a 4wd id still have to cut out the old ifs and id still do chevies, and id still have to modify the floor boards for the duals. So really some brackets and a new tranny seem to be the main delima
Old 02-11-2009, 04:23 PM
toyota4x4907's Avatar
He could get a Prerunner...suspension is identical
Old 02-11-2009, 06:06 PM
turbo93svt's Avatar
makes sense to me (buying the 2wd) i just bought a 3rd gen 4runner im doing a sas and leaf spring swap in the rear, oh yeah and an atlas transfer case so thats why i started with a 2wd everything will be changed anyway
Old 02-11-2009, 09:06 PM
92yotaman's Avatar
ok thats what i like to hear, now i know a taco is harder to SAS because you have to change oil pans correct? are there any other hidden surprises with a SAS taco?
Old 02-12-2009, 05:20 AM
turbo93svt's Avatar
i spoke with pepe at all pro offroad and he told me that i just have to box the front frame rails he didnt say anything about oil pan i also dont see how the oil pan could possibly be a problem if your lifting the truck that would put the axle a long ways away from the pan anyway. but im certainly in the learning stages on this one so you might want to call them. Pepe has a taco thats sas'd so he would be the guy with the info.
Old 02-12-2009, 08:48 AM
scuba's Avatar
is pepe the one with a green taco on full width axles ?
Old 02-12-2009, 08:55 AM
turbo93svt's Avatar
i havent actually seen it i live in new mexico i have just talked to him by phone, he did tell me it was a tacoma with sas leaf sprung.
Old 02-16-2009, 10:22 PM
bigtrucknwheels's Avatar
Location: Where it always works if you work it, in Sunny Selinsgrove, PA
yes.
he was a member here (briefly), then was banned due to major drama llama issues...
Old 02-16-2009, 11:06 PM
scuba's Avatar
Originally Posted by bigtrucknwheels
yes.
Yes, Ive been aware of the rock brawlers issue for a while, didnt know he was one. Although I managed to find him on TTORA, Whenever I have a day off im gonna head over to allpro and check his truck out
Old 02-16-2009, 11:08 PM
scuba's Avatar
actually, If you dont want your pumpkin and front sump oil pan getting in a major fight its very advisable to put a rear sump oil pan from a t100 2.7. check out TTORA.com for more stuff on Taco sas's
I8URSVT
04-17-2016 03:38 AM
urabus
11-10-2015 07:38 PM
Daenerysdad
10-01-2015 07:33 PM
83
18
09-21-2015 06:15 PM
May-39
09-06-2015 01:05 PM
Quick Reply: 2wd to 4wd
