2ng gen rear window defrost
OK, I did a search and apparently this is a pretty common problem, but I think the cause on mine is a little more uncommon. No simple broken/unplugged wires here...
Are these two wires supposed to clip to the window? I think one of the clips is in the plug, but the other is missing. Are they supposed to go on the white patch?
Anyone have pix of what it's supposed to look like?
Can I cut the plugs off and solder the wires straight to the window? Other recommendations?
THANKS!
THANKS!
If I remember correctly there should be 2 wires atached to that white patch. It's been a while since I had problems with my defroster. There's should be 2 male connectors attached to the window, and the wires clip on them.
I don't see any problem with soldering the wires directly to the window.
i did just that last year. there must be something else between the switch and the glass as mine doesnt work. currently, im using a 120v car heater on a timer to keep the windows clear during the cold weather. it stays warm enough inside until the heater starts pumping out warm air.
lee
lee
06-01-2021 01:51 PM
jasonty
41
12-23-2018 01:00 PM
icentropy
07-14-2015 10:23 AM
FS[SouthEast]: 1st Gen 4Runner Slider Window, Driver Side
coryc85
07-06-2015 04:07 AM
