2nd gen won't crank
Old 10-04-2005, 03:16 AM
91 4Runner's Avatar
2nd gen won't crank
I go out to the truck on Saturday, and for no reason it won't crank over (like the battery is dead.... No click, spits CD out of player and resets clock and cd settings) So I think "OK I must have left something on" Check everything, and nothing was left on... So I charge the battery and try again.... Nothing no click nothing.... So I boost it with another battery - starts right up... So I think OK I need a battery, so I buy an Optima Red top. I think OK this will fix it. Install the battery and nothing, so I boost it and it fires right up.... So now I'm at a loss, I'm thinking maybe starter? I don't know.... The charging system works (guage reads about 16 volt, and I can remove the positive terminal while it's running and it continues to do so..... If it is the starter will a 4cyl starter fit a 6cyl? Any ideas? Need help quick
Old 10-04-2005, 06:30 AM
celica's Avatar
Try you battery terminal connections. If they are dirty, corroded it will do the same thing, when you jump it you have a clean connection from the jumper cables. Cleant the cables, post and give it a try.
MAtt
sandyota
02-04-2021 11:16 AM
calderp
Engine Swaps
08-16-2016 05:15 PM
calderp
07-27-2015 09:58 AM
raiderhawks00
07-08-2015 06:23 PM
Steezy96yota
07-06-2015 10:00 AM
Quick Reply: 2nd gen won't crank
