2nd gen trac bar/ panhard bar removal - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 08-04-2005, 08:57 AM   #1 (permalink)
i am trying to remove my trac bar or panhard bar (whichever you may like to call it) and the upper mount bolt wont seem to come out. is there a trick to getting this one out or am i missing something here? i would assume once the nut is removed the bolt should be able to come out- no such luck for me. any advice?
__________________
Current 1998 SR5 3.4L 4x4
4runners of the past:
2000 SR5- the wifes beasty
The Green Money Pit
1992 4runner Medalist
-2.5" susp lift
-2in body lift
-15 inch Pro comp Rock crawlers
-33x12.5 destination MT's
-k&n filter
more to come with more money.....
*update- cost me too much money- now sold*
Y2Krunner is offline
Old 08-04-2005, 09:23 AM   #2 (permalink)
geneius's Avatar
The one on the driver's or passenger's side?
__________________
Gene's 95 LTD 4Runner
Downey HD Coils, Spacers & T-Bars (3" Lift) | ProComp ES3000 Shocks | Warn Premium Hubs | 15x8 Black Rock Crawler Rims
BFG AT/KO 33x12.5x15 | K&N Drop-In | 4.88 Gears (stock) | ProComp ES2000 SS | Idler Arm Gusset | SS Braided Brake Lines
ISR Mod | Diff Breather | Hella 500s | Cobra 75WX ST | FireStik Firefly | Tranny Cooler | All Pro Off Road Sliders | More Later...
geneius is offline
Old 08-04-2005, 09:31 AM   #3 (permalink)
anthony1's Avatar
Send a message via AIM to anthony1 Send a message via Yahoo to anthony1
The driver side one, the bolt is actually part of the axle.
The passenger side one, it's been in tension all this time, so after you loosen it, put the nut back a little so you dont' ruin the thread, then hammer it till it start to back out the back end.
__________________
http://www.angelfire.com/ca6/954runner
GOD's Country Best Seen In A 4 Runner. SAS front: lf,ARB,Ml4",Marlin arms, rear: cable elock,APlinks,OEmu860,35MT/R 5spd, 4:1.
..."But officer, that was not an illegal turn, it was just an undocumented turn."
anthony1 is offline
Old 08-04-2005, 09:42 AM   #4 (permalink)
Guest
Spray with some "Rust Bust" first, then beat with hammer.
94x4 is offline
Old 08-04-2005, 11:10 AM   #5 (permalink)
its the upper one- the passenger side. does this mean the bushing is shot or something? is it all fine to put back together with original hardware?
__________________
The Green Money Pit
-2.5" susp lift
-2in body lift
-k&n filter
Old 08-04-2005, 11:45 AM   #6 (permalink)
Guest
A visual inspection should serve to determine whether or not it's "...fine to put back together with (the) original hardware." Although most here would advocate upgrading to better/new materials whenever possible.
94x4 is offline
Old 08-04-2005, 11:47 AM   #7 (permalink)
are the bushing and bolt available from toyota? does anyone know this and maybe for how much if they have replaced them before
__________________
The Green Money Pit
-2.5" susp lift
-2in body lift
-k&n filter
Old 08-04-2005, 11:49 AM   #8 (permalink)
Robinhood150's Avatar
Send a message via AIM to Robinhood150
Bill from pennsylvannia had a hard time with this one, he ended up torching it out and having to piece together a new bushing/bolt. Search around in the off road section.
Meanwhile, us California 4runners just have to spray it with oil and tap it out.
__________________
Steve. '93 4Runner V6 Auto 4x4
Robinhood's Lair. || Gettin' Off 4wd Club member
Lots for sale:5.29 ARB IFS third member... Click
Sierra Club policy: [A reason to close trails] ...Physical soil damage, often readily visible, resulting in:
a. Erosion, causing soil loss and damage to stream banks, streams, and fish habitat...
Lesson...Stay on the TRAIL!
Robinhood150 is offline
Old 08-04-2005, 12:41 PM   #9 (permalink)
geneius's Avatar
I did what Bill from PA did. I cut the bolt off, then torched the crap out of the bushing till it fell out. Cleaned it up w/ a screwdriver and then using a shock bushing from Advance Auto Parts ($4.99) I trimmed it and stuck it back in. Works like a charm.
__________________
geneius is offline
Old 08-04-2005, 12:44 PM   #10 (permalink)
completely off topic now- anyone know what years i can remove the manual hubs from to do a conversion on my 92 4runner with auto hubs?
__________________
The Green Money Pit
-2.5" susp lift
-2in body lift
-k&n filter
Old 08-04-2005, 01:01 PM   #11 (permalink)
geneius's Avatar
I don't know, but I went the easy (not cheap) way and just bought some WARN premium hubs. Didn't need to rebuild, it was simple. About 30 minutes per wheel and it looks so nice and shiny.
__________________
geneius is offline
Old 08-04-2005, 02:02 PM   #12 (permalink)
anthony1's Avatar
Quote:
any IFS 4runners up to 95 or IFS pickup up to 95 1/2
__________________
anthony1 is offline
Old 08-04-2005, 02:05 PM   #13 (permalink)
leebee's Avatar
first and second gen runners except the solid axles from 84 & 85 should be interchangable. grab new gaskets from the stealer, clean up the mating faces on the hub body, cap and wheel location, check there is sufficient grease and bolt them on.
lee
__________________
93 sr5 v6 auto, 4x4
Photos http://s866.photobucket.com/albums/a...albumview=grid
there are quite some attractive ladies on here with Toys. (compliments of ironmike)
ifsc 3(.0)
http://tlca.org
www.of4wd.com
www.sontt.com
leebee is offline
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Please Read if you have installed a 3rd Gen PanHard/Trac Bar drop bracket sschaefer3 95.5-2004 Tacomas & 96-2002 4Runners 10 03-15-2007 07:24 AM
2nd Gen Adjustable Panhard bar Marc P Offroad Tech 22 12-21-2006 10:46 AM
Sonoran Steel 2nd Gen 4Runner Drop Trac Bar/Lift Proportion Valve Bar sschaefer3 Vendor Advertising 55 11-20-2006 06:31 AM
3rd gen Adjustable Trac/PanHard Bar ROOFGOOF 95.5-2004 Tacomas & 96-2002 4Runners 15 10-13-2006 07:36 AM
2009 InternetBrands, Inc.
