2nd Gen Sunroof Control Removal
Does anyone know how to remove the little plastic cover on the sunroof controls in a 2nd Gen 4Runner? I see a few tabs that pop off but canot remove whatever is holding it on on the left.
Thanks
Thanks
sunroof issues
Look at your sunroof swich, are there any screws you can see anywhere? If not, then you have to pry the bezel off, it just pops straight out. This is ONLY IF YOU DON'T SEE A SCREW! Pop that out and the rest should be no problem.
Todd
Todd
The only screw I see it througha hold under inside the card holder thing. That screw is big and very hard to turn. I am hesitant to remove it b/c it seems to be more part of the sunroof itself.
The little bessel pops off except for the drivers side. Something(maybe a plug) is holding it on there.
Does anyone have any diagrams of this area?
I broke mine so I know how to do it now. Pull down from the passenger side then slide toward the passenger side. The drivers side does not pull straight down. Yes it is hard to pull but it does come off (only from thr passenger side)
Re: sunroof issues
I removed my "safety switch" since I couldn't get mine to close due to a broekn part in the safety thingus.
Sunroof issues
Well damn it! Sorry guys that is they way mine came out for me. I checked for you guys and I can get the bezels to you for my price as an employe, $14.76. I will only charge $5.00 for shipping, which brings you both to $19.76 after shipping. Sorry guys, you know I wouldn't try to intentionally mislead you.
Todd :pat:
Todd :pat:
finally....but here's the problem
I finally got my cover off in one piece! It was pretty easy after hearing how to do it. Thanks ya'll. Now my only problem is the switch(maybe) itself. Okay, here is the problem....... THe sunroof will open just fine as if it were brand new. However, when you go to close it, It don't even make an attept to close. No noise or anything! You have to turn the big screw to close the sunroof. It pisses me off b/c the sunroof was a feature that I was looking for when buying my 4runner. It is a '91 if it makes any difference. Hope someone can help. Thanks
I had that problem too it was the contacts inside the switch. I just toggled mine back and fourth like a maniac and it started working. You can also go the hard way by taking the switch apart and using a pencil eraser to clean the contacts. If that's your problem.
Re: Sunroof issues
Todd :pat:
Todd :pat:
JK
I know, I deserve it though! Sorry about that guys, just let me know if you want to order a new on or if you guys figure out what is broken let me know. Here are a few prices right now, first set of numbers will be production dates, part number, color, and price.
9108-9511 88460-35010 switch for roof (no color) $33.70
9108-9308 84864-89101-E0 bezel (Tan) $14.65
9108-9511 84864-89101-03 bezel (Gray) $14.65
9108-9511 84864-89101-J0 bezel (Blue) $14.65
9308-9511 84864-86101-E1 bezel (Oak) $14.76
9511-9807 84860-35020-B0 switch/bezel (Moon Mist) $47.98
9511-9807 84860-35020-E0 switch/bezel (Oak) $47.98
These should cover the most of you guys for bezels and switches, just let me know if or when you want one and we will get it to you.
Todd
Todd
06-01-2021 01:51 PM
kirkrunner
07-27-2015 07:59 PM
Steezy96yota
07-06-2015 10:00 AM
2nd, 4runner, 848648910103, 8486489101e1, 91, 92, control, generation, oak, removal, remove, slow, sunroof, switch, toyota
