Thread Tools | Search this Thread | Display Modes |
#1 (permalink) |
2nd gen rear shock removal tip...
Not sure on what your patience is like but mine was running out trying to remove the upper nut on my 170k rear shocks.
Seems 13 years of rust and alt had done a number on the thread and even with a strap wrench holding the shock body, progress was painful to the point of negligible. Seems if you disconnect the lower mount and strap the shock to the axle with a bungee in a more vertical position than when they are installed, a Sawzall fits in there nicely. Just make sure you aim ABOVE the cupped steel washer that supports the upper bushing and you can remove your rear shocks in under 3 mins per side. If you cut it off below there, a large weld will not allow whats left of the upper mount to pass back through the hole in the frame. After fussing with the DS for 20 mins, I had both off in another 5 mins once I got the right 'wrench' David
__________________
98 Limited: Taco/Tundra TRD/OME lift, diff drop, LC rims, 32" REVOS, TJM T-17, Magnaflow 93 SR5 V6 4WD *** TOTALLED **OME lift, Aisin hubs, 31x10.5 Dueller ATon 15x8 AR23's, clears, Silverstars, K&N, Dynomax, Yakima ... 03 V8 Sport. Jaos Center Protector, Landmaster Dual beams, Silverstars, RD leather interior , TRD rims/X-Terrains - gone :-( 99 SR5 "Highlander", SC'd, SAW/Downey,32's,Addco,deck plate, TRD cat back, 1.5Kw stereo ...gone , not forgotten 96 SR5 Dune... 1.5kw stereo |
| Sponsored Links |
#2 (permalink) |
hahahahaha NIIIICE!!
![]() ![]() the first time i yanked mine off i stuck a cresent wrench up there then used a BIG set of channel locks to rotate the shock... got em off in about 2hrs.... I like your method better! ![]()
__________________
3vze, 4x4, sr5, 90, auto, LSD 2x dB Drag World Finalist 2003 Nopi Nat. Street B champ 2004 SBN Street C champ 2004 SBN Advncd NW Champ 2004 Former WR Holder in NW. SPL: 159.8db @ 42hz In loving memory of Jamie Riggs 5/15/85 - 10/8/04 |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Question on 2nd gen rear shock removal | ROMAD | 86-95 Trucks & 4Runners | 14 | 12-14-2007 05:48 PM |
| 2nd Gen 4Runner Rear Upper Shock Brackets | Phalanx | 86-95 Trucks & 4Runners | 10 | 10-11-2007 12:30 PM |
| Question on rear shock removal for 3rd gen | ebelen1 | Offroad Tech | 15 | 08-30-2005 01:10 PM |
| 2nd Gen Runner Rear Upper Shock Mount | Phalanx | The Fab Shop | 9 | 06-25-2005 03:31 PM |
| Great tip for 2nd Gen rear windows | Firefyter-Emt | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 04-13-2004 04:36 PM |
