2nd Gen OME Steering Stabilzer Part #
Old 07-08-2004, 03:30 PM
Godzilla's Avatar
I was doing some rust control and chasis painting when i noticed the crappy stock steering stabilizer. OME looks like the way to go, could anyone confrim the part number for the kit. Thanks
Old 07-08-2004, 03:46 PM
gwhayduke's Avatar
I'm due for one also...gonna get rid of the Rauncho. Good thing I saved the old bolts.
Old 07-08-2004, 06:19 PM
SolidDigital's Avatar
I think it's an OME-SD33?
Old 07-08-2004, 06:20 PM
Scofco's Avatar
Ome-sd33
Old 07-08-2004, 07:14 PM
Godzilla's Avatar
thanks for the part number guys. my runner and i thank you
Old 07-08-2004, 07:32 PM
Co-Founder/Administrator
Staff
Corey's Avatar
Be sure to check out Joey's write-up in our Tech section.
He did the OME also.
PS...
If ya need a pickle fork for the install, I hear 4route carries a very sharp one in her purse with her at all times
I'm sure she'd loan it to a fellow YotaTecher to help with your install.
Old 07-08-2004, 08:36 PM
ROMAD's Avatar
Don't want to derail the thread but you should at least consider the Pro-Comp ES2000 SS for 29.95, 2nd gen P/N: 219500
Relevant link for Pro-comp SS thread
Old 07-08-2004, 09:21 PM
Godzilla's Avatar
does the pro comp ss come with the kit similar to that of the ome, as in a perfect fit using all original mounting locations? I hear with the rancho you have to add a bracket or some type of nuisance step. Fill me in, I have pro comp es3000 shocks and i like them so far. thanks
Old 07-09-2004, 12:09 AM
WSU4runner's Avatar
Which one do we get? I was looking at the link for the Procomp one and it just confused me
Old 07-09-2004, 09:06 AM
ROMAD's Avatar
The Pro Comp ES2000 SS for my 1995 uses the factory mounting locations and included all needed hardware. The only 'hardware' required is a big mounting stud that goes into the hole in the steering linkage where the factory SS bolted.
Once you get the factory SS off the vehicle everything bolts back into the factory places (using the supplied stud to mount the SS to the linkage)
I am sure OME is good stuff but I am very happy with my Pro Comp for 50 bucks less!
Old 07-09-2004, 09:32 AM
UKMyers's Avatar
Spend another $20 and get a quality part. Pro Comp is junk IMO. At least their shocks anyways and since a steering stabilizer is pretty much a shock I would think it would be the same way.
06-01-2021 01:51 PM
Avenged
07-09-2015 07:55 AM
ptb12
07-05-2015 01:49 PM
Vargntucson
07-04-2015 12:15 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd Gen OME Steering Stabilzer Part #
