2nd Gen ADD Sensor Help ?
Old 08-25-2004, 07:52 AM
RobG's Avatar
When putting the finishing touches on my front lift last night I noticed that the wire connecting the sensor on the front differential (I assume it is a sensor) wasn't connected and the other end of the wire coming from the wiring harness has the connector missing.
I'm not sure how these wires need to be connected:
- the 2 wires comming from the wiring harness are pink and green.
- the 2 wires going into the front differntial are green, one has a white stripe the other a yellow stripe.
Any wiring advice would be greatly apreciated.
Does any one know what this sensor does and if it needs to be conected for 4WD to engage? I hear a noise when shifting to 4WD but no light comes on.
Thanks,
Rob
Old 08-25-2004, 08:23 AM
Sbrut95's Avatar
Thanks,
Rob
I cant help you with the wiring part, but mine came unplugged somehow and my light wouldnt come on. It still engaged into 4wd. So that should still work. Just put into 4low and theres no way you cant tell.
Old 08-25-2004, 11:25 AM
eric-the-red's Avatar
The sensor only switches on the 4WD light, your front diff will still be connected without it. And the wiring shouldn't matter, it's a simple switch. One wire goes in and the other is out, when in 4WD the switch closes and turns the light on.
Old 08-25-2004, 01:16 PM
ErikB's Avatar
Ditto.
Old 08-25-2004, 01:21 PM
Sbrut95's Avatar
Thats what I was trying to say. Thanks Eric the red for making it a little more clear.
Old 08-25-2004, 02:01 PM
95_4X4Runner's Avatar
As part of the ADD defeat mod, it says to trace those wires up, and just splice them together, and the 4wd light will work as normal.
Old 08-25-2004, 02:52 PM
Cebby's Avatar
Mine doesn't work right now since I pulled the ADD junk...
Old 08-25-2004, 05:38 PM
914runner's Avatar
I pulled the ADD junk and mine works
Old 08-25-2004, 05:45 PM
Cebby's Avatar
Did you swap axle tubes, or just do the defeat mod in the 4x4wire tech? Did you tie the wires together like suggested above?
Old 08-25-2004, 05:48 PM
914runner's Avatar
I just defeated it for the mean time when I did my engine swap. I am looking for a non-ADD 4.56 ratio front third from a truck to put in the front to go along with a 4.56 ratio rear E-locker!
EDIT: no I did not tie the wires together.
Old 08-27-2004, 06:43 AM
RobG's Avatar
Thanks for the help !!!!
Looks like the trip for this weekend is back on.
06-01-2021 01:51 PM
nonstop
07-24-2015 06:29 PM
Steven.m.paulk
07-24-2015 01:44 PM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd Gen ADD Sensor Help ?
