2nd gen 5sp tranny oil
Old 07-03-2003, 01:15 PM
NCSU-4runner's Avatar
how much oil is supposed to be in there? i took the shifter out to get it welded ( refer to this post for why LINK ) and i cat see any visible oil down in the mechanisms. theres a good coating on all the parts but i dont see any actual volume of oil visible from the top. is that normal? just want to know cause i ran it without the shifter sealed real well for about two weeks and i know i lost some cause the top of the tranny had oil all over it when i took the shifter boots off.
the oil was replaced back in november with some other routine maintence by the stealership (before i got involved in offroading and do-it-yourself maintinence) so ive never seen the top when it was full.
Old 07-03-2003, 01:31 PM
rimpainter.com's Avatar
That's normal not to see it from the top. If you have a hunch it might be low, undo the fill bolt and stick your pinky finger in there, you should have nice clean gear oil on the end of your finger. Just remember to put a new fill bolt gasket on before tightening it back up.
Old 07-03-2003, 03:32 PM
uhh . . . where exactly is the fill plug. i looked around and i see alot of bolts, dont wanna just start undoing them randomly
Old 07-03-2003, 03:45 PM
Without access to any pictures or the FSM, this will be tough...
Its facing the driver side door if you are looking at the transmission...a 19mm socket is required to get it off/on...that's about the best I can do.
Anybody have any pics?
Old 07-03-2003, 03:57 PM
19mm socket should help me track it down, be back in a few min
Old 07-03-2003, 04:10 PM
well the only large size bolt i found on the driver's side took a 15/16th socket (same as the diff drain bolt) but it was the only big one around so i loosened her up and oil started leaking around the edge immediatly. good thing i didnt think to check if my car was sitting level first. i was parked on a slight hill so that the drivers side tires were slightly declined with respect to the passegner side tires. guess that means its still pleny full ehh? and it wasnt perfectly clean oil, but good enough for now.
06-01-2021 01:51 PM
Iceman4193
07-15-2015 04:48 PM
madxman21
07-09-2015 10:26 AM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
Quick Reply: 2nd gen 5sp tranny oil
