2nd Gen 4runner quickie
Old 12-14-2003, 11:55 AM
miketerrizzi's Avatar
I got a quick question, I purchased my 4runner used and I have no idea what ECT does, when i turn it on and off it doesnt seem to do anything noticable.
Old 12-14-2003, 12:35 PM
Paul H.'s Avatar
ECT stands for electronically controlled transmission which means that when pressed, the shift points will change giving you more power from the get go. Use it for towing, going up large hills or lead footed starts from stop lights. Hope this answers your question. A dash light should come on when the button is pressed. You will notice the difference when you excelerate.
Old 12-14-2003, 12:37 PM
DrumheadAR's Avatar
Before you get bombarded with people yelling at you to do so, i would recommend doing a search for this. (use the flashing green button at the top of the page), but to quickly answer your question....
The ECT (Electronically Controlled Transmission) Button changes the shifting points of your transmission. This helps you if you are towing, or trying to climb a steep, long hill. It allows the engine to rev higher before shifting.
Hope this helps, try the search for more complete explanations.
thanks my 4runner is soo slow!
Old 12-14-2003, 12:39 PM
search is flashing "USE ME USE ME"
sorry
Old 12-14-2003, 06:11 PM
Cebby's Avatar
The ECT button will make your Runner less slow, but nothing short of a swap will make it fast... (I'm in the same boat - ECT on always for a little extra...)
06-01-2021 01:51 PM
tpd143
07-07-2015 09:06 AM
Steezy96yota
07-06-2015 10:00 AM
HRDC0R19
07-05-2015 06:43 PM
CJ94yota
07-03-2015 10:14 PM
Quick Reply: 2nd Gen 4runner quickie
