YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Home Photo Gallery Register Search Today's Posts Mark Forums Read Tread Lightly Wiki
Thread Tools Search this Thread Display Modes
Old 05-16-2008, 06:40 PM   #1 (permalink)
285s on 2.5 spacer lift
i have seen 100 different seneros will 285s fit on a 97 4runner limited with a 2.5 lift
fr3533 is offline
Sponsored Links
To remove this ad, register today!
Old 05-17-2008, 09:20 PM   #2 (permalink)
Cuthroat72's Avatar
as far as I know they should. Like I am sure you have heard, make sure that if you go to different wheels than stock that you have proper backspacing so you don't rub your tires on the upper control arms. I presently have a '99 with a spacer lift on it and I clear 285's with no problems. Good luck!!!
Cuthroat72 is offline
Old 05-17-2008, 10:04 PM   #3 (permalink)
Sloan's Avatar
99s are also the tallest coils to so the low rider years might no be able to.
__________________
'01 Toyota 4Runner Limited
Mods Listed Here:My 4Runner
Quote:
Originally Posted by Corey View Post
Once must also realize that YotaTech has always been open to both 2WD and 4WD trucks and SUVs. This means the gnarliest off road rig, to the lowrider that scrapes its belly over a dime in a parking lot.
Sloan is offline
Old 05-18-2008, 01:13 AM   #4 (permalink)
etan's Avatar
i run 285 75 on a 3 inch toytec lift with stock wheels on my 98 4runner with hardly any rub issues. no rub on the a-arm or fenders. it just rubs frame at full lock. which wasn't even a big deal for me untill i proper rims and maybe additional lift.
__________________
984runna
etan is offline
Old 05-18-2008, 08:15 AM   #5 (permalink)
pfdaxe's Avatar
No rub on my 2000 with 285's and a 2.5" lift...
__________________
My 2000 TRD 4 Runner
My email
pfdaxe is offline
Old 05-18-2008, 10:47 AM   #6 (permalink)
4X4snowRunner's Avatar
Quote:
Nice 4R....I have OME 3" lift and 285's to be install on my american racing wheels (16x8). You are not using wheel spacer right! I assume I dont need it.
__________________
4X4snowRunner
1998 4Runner SR5 V6
Heavy Duty for hauling & towing
front suspension:
OME882
OMEn91s
5mm trim spacer
sonoransteel tapered 1" diff. drop
rear suspension:
OME891
OMEn86
5mm trim spacer
sonoransteel adjustable trac/panhard bar
285/75/16 Toyo Open Country MT for summer 265/75/16 Geolandar i/T for winter
16x8 Painted American Racing Wheels
Borla Exhaust Cat Back
K&N Drop in Filter
4" Deck Plate
4X4snowRunner is offline
Old 05-19-2008, 12:28 AM   #7 (permalink)
Jdizzydub's Avatar
I ran 285/75 on my stockies wrapped in Toyo Mt's with a 2.5 coil spacer/OME set-up and got no rub, too! But I did minor trim on the inner fender well, by the pinch weld and grinded down the UCA's a bit for piece of mind. Only rubbed at full crank. No wheel adapters/spacers needed with 4.5 bs wheels.
__________________
97' 4RUNNER SR5 4x4
Lift:OME 881's OME Fronts w/ TOYTEC top out spacer, OME LC Rears
2in. 4crawler BL, SS Diff drop, Custom welded drop bar
Performance:Yellow Top,Custom Dual Vortex Exhaust, Magnaflow Hi-flo CAT, K&N FIPK, Diff Breather Mod
Wheels & Tires:315 16x9's on MOTO METALS
Lights:Silver Reverse Glow Gauges, Hella 500's
Armor:Trailgear Sliders, Taco ARB
"Sounds stupid. . .sign me up!"
Jdizzydub is offline
Old 05-19-2008, 06:48 AM   #8 (permalink)
pfdaxe's Avatar
Quote:
Thanks! No spacer installed. Just the 16"x8" rims...
__________________
My email
pfdaxe is offline
Old 05-19-2008, 10:54 AM   #9 (permalink)
Nice
Thank you for your reply. Now less to worry about. Yeah....I got these Toyo Open Country MT's report are great on road and off road. I'll post some pics if I figure how to post multiple pics.
__________________
4X4snowRunner
1998 4Runner SR5 V6
front suspension:
OME882
OMEn91s
5mm trim spacer
rear suspension:
OME891
OMEn86
5mm trim spacer
K&N Drop in Filter
4" Deck Plate
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
3 spacer lift fr3533 95.5-2004 Tacomas & 96-2002 4Runners 3 03-14-2008 10:08 PM
Spacer lift Hoopster 95.5-2004 Tacomas & 96-2002 4Runners 16 02-13-2007 01:21 PM
How bad do 285s rub w/no lift jeremys73 95.5-2004 Tacomas & 96-2002 4Runners 10 10-20-2006 08:18 PM
Finally Complete - OME lift, 285s, TJM Renegades Offroad Tech 26 10-09-2005 04:08 PM
spacer lift: topout extender vs preload spacer Rishi Offroad Tech 15 04-17-2005 04:18 PM
Advertise on YotaTech.com
Powered by vBulletin® Version 3.6.4
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
2002-2008 Yotatech.com
