285's with a body lift? - YotaTech Forums
YotaTech Forums
Go Back   YotaTech Forums > Toyota Forums Available > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Welcome to Yotatech!
Welcome to Yotatech,
Old 11-26-2006, 11:42 AM   #1 (permalink)
HuskyRunner's Avatar
So, Ive got some plans for my 98 sr5, but need some help. Will 285/75/16's fit with only a body lift? If so, how big? 1" or2"? I realize that a body lift won't improve clearance or performance, but my tires are shot and I would like to go up to 285's now, and when finances allow get a Sonoran Steel system 1 lift. Also I know that if the tires will fit I'll need either spacers or new wheels, but what backspacing or spacer size? Thanks for your help.
HuskyRunner is offline
Old 11-26-2006, 11:52 AM   #2 (permalink)
d0ubledown's Avatar
Send a message via MSN to d0ubledown Send a message via Yahoo to d0ubledown
i think you can get away with an inch spacer, or 4.5 BS'd wheels. they will tuck nicely in the wells. stock is 4.3ish(i think? someone correct me). some run stockers with 285's, but i think theyre lifted. alot of steelies are about 3-3.75ish and stick out a bit more (which is what most run). a BL should also clear 285's...id go with a 1.5" just to be safe though. its an easy install. which 285's you thinking about going with? when ya get em on...lets go out wheelin! err..maybe not in this much snow..
and your wrong..BL WILL give clearance...for your tires
__________________
sonny
1998 4Runner LTD. Fabtech CO fronts, OME/Pro Comp rears, SS rear links, Revtek diff drop, oem elocker, ARB RD90, 4.88's, 315/75/16 MT/R's on FZJ-80's, Trail Gear sliders, ARB Prado Bar, 1.5" 4Crawler BL, Tundra Brakes, wabfab disco's, IPF's...satoshi'd deckplated & ISR'd.
SOLD!!!
new ride: 1997 FZJ80. ome/arb/bfg/etc.
when clinton lied..nobody died
d0ubledown is offline
Old 11-26-2006, 12:05 PM   #3 (permalink)
Angus1's Avatar
Ive got an 04 taco I used front top load sring spacers 2" and cleared 285's with a little triming.
Angus1 is offline
Old 11-26-2006, 12:45 PM   #4 (permalink)
Thanks for the quick reply Doubledown. Where would I begin to look for spacers in the lower mainland? I like the looks of the stock wheels, but if black steelies are cheaper... As for tires I'm leaning towards BFG A/T's. Yeah, too much snow right now...my truck is a white mound in the driveway. we've got about 10" since 6pm last night.
Old 11-26-2006, 12:52 PM   #5 (permalink)
d0ubledown's Avatar
talk to taran over at bigcountrycustoms.com. i just got a quote from him. 1.5" are on sale $95+ tax/pair and in stock. im sure you could get a good deal on 2 pair if you want to run all 4. i think 1" are a tiny bit more, but he'd have to get em for ya.
steelies are cheap. im sure if youre getting a set of bfg's you should be able to get a good deal on steelies all at one shop. if you can spring for steelies instead of spacers..do that. then you'd have your stockers for a backup set if you need.
and yes... a rear diff locked in 2WD with MT/R's on snow is NOT the ideal winter setup..but it sure is fun!
__________________
sonny
SOLD!!!
Old 11-26-2006, 03:50 PM   #6 (permalink)
Super Moderator-Sponsoring Member
Staff
waskillywabbit's Avatar
Send a message via AIM to waskillywabbit Send a message via MSN to waskillywabbit Send a message via Yahoo to waskillywabbit
2" body lift will clear 285s for onroad use...you'll need more lift to wheel them and not rub like a fat woman in cordoroy pants.
waskillywabbit is offline
Old 11-28-2006, 06:02 PM   #7 (permalink)
Would it rub only on the pinch weld? or would there have to be trimming and beating? It would only be temporary but...don't really want to destroy the truck or the tires.
Old 11-28-2006, 06:21 PM   #8 (permalink)
Staff
Without a body lift...you'll rub means you won't be able to turn.
Old 11-29-2006, 04:12 AM   #9 (permalink)
But WITH a body lift, where would it rub? It looks like a little pinch weld pounding should fix the majority of it, right?
Old 11-29-2006, 04:49 AM   #10 (permalink)
tacoma728's Avatar
IMO, six inches of lift is minimum for this size tire? My 33x12.50s still rub and i have a six inch lift. It is better to be safe than sorry.
tacoma728 is offline
Old 11-29-2006, 04:50 AM   #11 (permalink)
AH64ID's Avatar
Send a message via MSN to AH64ID
Do you wheel the truck or just on the street?
A 2" BL allows for a 4" taller tire, so you should have no rubbing issues there, unless its on the aarm or frame.. A 1" BL allows for 2" bigger tires, so that should also work, and maybe just barely kiss at full turn and full stuff on the pinchweld.
A spacer or spring lift that isnt a bracket lift wont provide the clerance you need if you wheel the truck, you will need it and a BL to not rub. The BL is actually what provides the clearance, the springs/spacers just provide the added ride height and clearance under the frame...
__________________
-John
'05 Dodge 3500 SRW 4x4 SLT 5.9 Cummins QC LB NV5600
2003 SR5 4Runner, V6 4WD. 1" cornfed lift
Previous Toyota's '92 Red Truck NALA
Speed doesn't kill, its the sudden stop that hurts.
AH64ID is offline
Old 11-29-2006, 04:58 AM   #12 (permalink)
tacoma728's Avatar
I wheel it in the mud and muck and up hills and everywhere, lots of flexing and turning. I have 3" spacer + 3" body.
Old 11-29-2006, 05:19 AM   #13 (permalink)
KyleT's Avatar
Quote:
You are most likey rubbing because you have a 12.5" wide tire. 285's are what, 11.4" wide? close to that though. width kills us vs. height.
__________________
- Kyle
Former Owner of -
1996 Sunfire Red Metallic 4Runner Limited updated 10/31/06
OEM/TRD Lift Kit #1 from Sonoran Steel with 1 Top-out spacer - Lexus GX470 rims - 295/70r17 Nitto Terra Grapplers Yukon 4.88's, E-Locked Rear, Waiting to blow up front diff #2
KyleT is offline
Old 11-29-2006, 05:57 AM   #14 (permalink)
AH64ID's Avatar
You have to remember that when you flex you take out the 3" spacer lift since you compress to the stock location.... so the 3" BL is providing the clearance, and the width is what is killing you, and possibly your BS on your rims. A friend of mine has a 6" on his taco and the 33's rub the plasitc liner... nothing a little trimming wouldnt fix, but still, He could probally run a 35x10.50 and not touch anywhere.
Quote:
Yeah, its amazing how much room you loose with wider tires..
__________________
-John
AH64ID is offline
Old 11-29-2006, 08:30 AM   #15 (permalink)
HUTCHSTACO's Avatar
width can be trouble, i don;t know but 3 inch body lift is a lot
__________________
2006 Tacoma 4x4 TRD Sport with 20's and 285 Goodyear Furtura's and 2 inch cornfed lift
2002 Tacoma Extra Cab V6 (SOLD)
HUTCHSTACO is offline
Old 11-29-2006, 08:33 AM   #16 (permalink)
04 Rocko Taco's Avatar
Send a message via AIM to 04 Rocko Taco Send a message via Yahoo to 04 Rocko Taco
its gotta be the width, on our trucks 3" will clear 33's for on road...off road you will rub a little "like a fat woman in courdory pants" (thanks Wabbit)
__________________
-Chris Tread Lightly!
04 Double Cab PreRunner. 3.4 - Auto
84 4Runner 4WD. 22R - 5 spd Lifted, Locked, 33x12.50
Disclaimer:My Photobucket is being revamped. If there are broken links, shoot me a PM. Thanks. ~Chris
Great Toyota Tech
04 Rocko Taco is offline
Old 11-29-2006, 09:11 AM   #17 (permalink)
HUTCHSTACO's Avatar
i like that, "like a fat woman in courdory pants", haha, its funny because its true
__________________
Old 11-29-2006, 09:22 AM   #18 (permalink)
tacoma728's Avatar
Yeah, next set i will go with might be 34x10.50. Although they are wider, i really like these tires and they do great off road. 33x12.50 BFG All Terrains.
Old 11-29-2006, 03:57 PM   #19 (permalink)
Excellent! Thank you for your help guys. It's settled - not done or paid for, but decided - 2" BL, wheels and 285's soon, and a Sonoran Steel kit when money allows. It's nice not to have to do it all at once. And it would look retarded to do the lift and BL first, then the tires. Now where's my wallet...funny, it's smoking and there is a hole where there used to be money. hmm.
Old 11-30-2006, 04:40 AM   #20 (permalink)
tacoma728's Avatar
yeah, looks like you have modifitis, he he. Good luck with the lift and tires when funds allow!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
285's on my 98 3.4L 6cyl 4wd w/ 2.5 lift??? kennyracer77 95.5-2004 Tacomas & 96-2002 4Runners 5 10-16-2006 02:34 PM
Lift? 285's? Sliders? Why bother? BT17R General Vehicle Related Topics (Non Year Related) 9 10-06-2006 08:20 PM
Just a 2" Body lift & 285's? Swede 95.5-2004 Tacomas & 96-2002 4Runners 8 09-08-2004 12:39 PM
how much more lift to fit 285's? Digger33 Offroad Tech 6 06-16-2004 07:54 PM
2009 InternetBrands, Inc.
