285/75/16 vs. 255/85/16??
Old 03-24-2005, 11:44 AM
ARB4STUNNA's Avatar
With my current set up I run 265/75/16's on stock wheels. I have a little over 2" of lift in front and a little over 2 1/2" in the rear. I want to go to a bigger tire but from what ive heard here on the board 285's will rub for sure and require a body lift. I was wondering if anyone has run the 255/85/16 bfg m/t's and If they fit in smaller applications vs. the 285/75/16. From the bfg website the 255/85/16's seem to be a tiny bit taller then the 285's but are more than an inch less in width. Any info would be great. And any pics of 3rd gen 4runners with these tires would be cool as well.
Thanks
Old 03-24-2005, 01:32 PM
Albuquerque Jim's Avatar
If you want to try a set of 285's come by some day and we'll swap mine on to yours so you can see if they rub.
Old 03-24-2005, 06:12 PM
dragr1's Avatar
You might be ok onroad, but offroad you'll rub the backside of the front wheelwells for sure with either tire.
Old 03-24-2005, 07:51 PM
JadeRunner's Avatar
That is correct. It's the A arm actualy. Go with the 285's. Iv'e been slightly rubbing my A-Arms with 285's for over 2 years and 40K miles with no concequenses or issues.
Old 03-24-2005, 08:26 PM
I'll show you how I trimmed my pinch weld to get maximum clearance.
Old 03-24-2005, 08:33 PM
toy4dad's Avatar
285-75-16
i have a 99 with revtek 3 inch lift will i have any problems with the 285 also i have the V-6 5speed will i lose alot of get up..thanks..
Old 03-24-2005, 08:44 PM
koyota93's Avatar
When mine was lifted, I didn't encounter any problems with rubbing with 285s. But then again, I never really abused it off-road either. I did have to trim my valence a tad, but maybe its because I have an aftermarket one.
Old 03-24-2005, 08:58 PM
It depends on how much stuff your springs will provide and how you wheel.
I can stuff my tires till the bump stops compress and droop until the ball joint hits the coil. Pretty much the maximum articulation from stock A arms.
Old 03-25-2005, 03:40 AM
pfbmgd's Avatar
After reading this thread .I guess putting 285s without a lift is a no go for me .
Old 03-25-2005, 07:19 AM
HaveBlue's Avatar
I have a set of Cooper Discoverer STTs in my garage just itching to be mounted on my old rims. They are 255/85/16. I bought those so that I could run a set of chains all the way around without ripping my A-arms apart. I can't run chains on my 285s. not enough room.
ashamsuddin
17
01-13-2023 03:17 AM
06-01-2021 01:51 PM
shisha1999
09-21-2015 08:22 PM
mxdw88
09-20-2015 03:13 AM
AndYota
08-10-2015 09:19 AM
Quick Reply: 285/75/16 vs. 255/85/16??
