YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 03-24-2003, 09:07 PM   #1 (permalink)
Personal Sales Rating: (0)
265/75R15 v. 31x10.5
what's the size difference between 265/75's and 31x10.5's? i read that the 31's would be the largest i could run on my stock tacoma but i'm currently running 265/75R15. is there a significant difference in tire size?
thanks
moschika is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 03-24-2003, 10:13 PM   #2 (permalink)
Darren's Avatar
Send a message via AIM to Darren
The 31x10.5's are 1-1.5" wider, providing they do measure 10.5".
265's are 9-9.5" wide.
__________________
2002 4Runner
MyColorado.org (CO landscapes, destinations & trip reports)
Darren is offline
Old 03-25-2003, 04:19 AM   #3 (permalink)
Send a message via Yahoo to ravencr
Is there a 31X10.50 for 16 inch rims?
Chris
__________________
http://www.utvrally.com
ravencr is offline
Old 03-25-2003, 05:25 AM   #4 (permalink)
Victor's Avatar
265/75r16 is 10.5 inches according to most manufacturers specs. They are also 31.8 inches tall so they are the same height as a 32x11.50 without the wider tire bulge. That is what I'm mounting on the new 16x7 wheels that came in yesterday.
265/70r16 is 30.7 inches tall and 10.5 inches wide just like a 31x10.5 . If you do go for a 16" wheel maybe you should consider the taller tire as it will increase ground clearance.
__________________
"Turtle" - Green 94 4Runner
Looks like one and about as fast
JDM altimeter/clinometer, 2002 Sport wheels, 265/75r16 MT/R, , OME stabilizer, BJ Spacers, Cruiser Coils, removed sway bars, rattle can paint for all that peeling clearcoat! Lockright front and rear.
Victor is offline
Old 03-25-2003, 06:08 AM   #5 (permalink)
RTdawgs's Avatar
Re: 265/75R15 v. 31x10.5
Quote:
thanks
you can run 265/75s on a stock tacoma. roughly a 32x1050.
__________________
2011 Land Cruiser
2008 4Runner (Sold)
2000 4Runner (Sold)
RTdawgs is offline
Old 03-25-2003, 08:14 AM   #6 (permalink)
Darren's Avatar
Quote:
265/70r16 is 30.7 inches tall and 10.5 inches wide just like a 31x10.5.
That's the problem with manufacturers specs. They're hardly accurate at times. Does the 4Runner's published ground clearance specs ring a bell?
My stock 265 Bridgestones are about 9" wide as well as my old 265 MT/R's. 265/75 MT/R's are 31" unmounted and sit at 30" on the truck, though they always measure small anyway. I believe BFG's are closer to matching the listed height.
I believe 285 MT/R's are 10.5" although I haven't measured them yet for some reason (I should have known such a post was coming). 285's are generally accepted to be 11.5" wide, but if you compare them to a 32x11.5, they aren't near as wide.
__________________
2002 4Runner
Darren is offline
Old 03-25-2003, 08:46 AM   #7 (permalink)
Victor's Avatar
I agree. That and the fact that a wider tire measuredment at the bulge doesn't equate to wider tread compounds the problem. Not too many shops will mount up a tire to let you look at it though but I know my 31x10.50's are narrower than spec also.
__________________
Victor is offline
Old 03-28-2003, 05:00 PM   #8 (permalink)
Threadstarter [OP]
Miss checking in a few days and i'm already 3 pages back. anyway
why the size numbering difference, if basically a 265/75 is the same as 32x10.5? and if a 265/75 is the same as a 32x10.5 then that's already larger then what i read as the 'recommended' maximum. yet this is what came on my truck from the dealer.
what would be the largest tire to put on a stock 98 tacoma then?
is there some reason why tire manuafacurers have differenct systems?
moschika is offline
Old 03-28-2003, 06:16 PM   #9 (permalink)
Victor's Avatar
If you have 16" wheels you can fit 265/75r16. If you have 15" wheels you can fit a 32x11.50. The wider 11.50 tire may rub at full wheel lock.
Larger than what is recommended? Isn't that the point with 4wheeling? You need more ground clearance to prevent damage to the truck. If you don't offroad much then don't worry about oversized tires.
__________________
Victor is offline
Old 03-28-2003, 08:08 PM   #10 (permalink)
HBoss's Avatar
265/70R16 = 30.6" overall height, 10.4" wide (tread face)
265/75R16 = 31.6" overall height, 10.4" wide (tread face)
31 x 10.5 = 31" overall height, 10.5" wide (tread face) <-- did that all really need to be said?
1 inch = 25.4 mm
A buddy of mine has 33 x 9.5's & they are significantly more narrow than my 265/75R16's.
__________________
1997 4Runner Ltd. Bilstein shocks, rear E-locker & riding on 32s.
Mods Pics
Tech articles, write-ups & more are available on my website.
http://www.hboss.net/4runner
HBoss is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
265, 26570r16, 26575r15, 26575r16, 31x105, 75, big, difference, explain, p26570r15, r15, r16, tires, truck, whats, wide
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
265/70 or 265/75 crolison 95.5-2004 Tacomas & 96-2002 4Runners 8 04-04-2007 07:12 AM
WTB: (4) 235/75R15 Tires [N8] The Classifieds GraveYard 3 05-23-2006 05:21 AM
opinion ? comparing 265\70R16 vs 265\75\R16 Lance 95.5-2004 Tacomas & 96-2002 4Runners 3 03-26-2005 06:01 PM
Tires - 265/70 vs. 265/75 - honest opinions wanted goldtaco9 95.5-2004 Tacomas & 96-2002 4Runners 52 05-06-2004 09:17 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
