| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
#2 (permalink) |
Kinda sounds like it....any water showing on the dipstick?
#3 (permalink) |
White, sweet smelling smoke would indicate coolant being burned. However, I'm not sure if the only way to burn coolant is because of a blown head gasket. Someone else with a little more knowledge should chime in...
__________________
1995 4Runner V6 4x4 |
#4 (permalink) |
might have a crack in the head or the block letting coolant in causing the white smoke. check if there is coolant in the exhaust tip when you start the engine.
__________________
=Jason= 2001 Tacoma DC PreReunner SR5 (looks stock to me) S/C and some other crap Last edited by 3.4v6; 10-15-2003 at 07:49 AM. |
#5 (permalink) |
nope, no water on the dipstick.
coolant in the exhaust tip........do you mean like a liquid puddle? nothing like that, just white smoke. Although this morning, it turned over and started fine, just white smoke again. Yesterday it seemed like it had to try and push out liquid. There mighta been coolant dripping out the exhaust then.....i didnt check ![]() I checked the coolant level and its definitely down in the rad.....I can see the core.....but the overflow is full.....If the gasket is blown could it be over-pressurizing the coolant system causing it to blow out to the overflow tank? thanks guys!
#6 (permalink) |
Can you rule out the timing chain? What I mean is by it eating away the cover and somehow letting coolant in somewhere.
__________________
1990 Ext. Cab 22re 5speed 4wd SOLD |
#7 (permalink) |
how would i check that? I've already got the rocker cover off.....and can see the chain....but where does it rub through usually? I can't seem to see the plastic guides(or lack of) that cause that problem.
#8 (permalink) |
The chain rubs on the bottom right of the cover when looking down from the top of the motor. Your problem sounds exactly like the infamous timing chain rub. My truck did the same thing when my chain wore a hole in the cover. Ran fine just spit out white smoke. Try looking down the right hand side of the timming cover, you will be able to see a reverse train track looking groove.
Sorry for your luck, but if that is it, put a DOA cam in there while you got the cover off.
__________________
Brad Work is for those who don't know how to plunder!! 92x-cab dlx 4x4 22RE, Pacesetter header, everything else is so stock it's not funny, cause I don't have the money! 04 F150 FX4 SuperCrew |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| Rough start and white smoke on occasion | Crazychopstick | 95.5-2004 Tacomas & 96-2002 4Runners | 16 | 05-31-2007 01:51 PM |
| white smoke AFTER headgasket repair | n8inks | 86-95 Trucks & 4Runners | 8 | 08-16-2006 08:46 PM |
| HELP! Overheated and white smoke is everywhere. | s t A t i c | 86-95 Trucks & 4Runners | 24 | 03-28-2006 05:18 AM |
| Help-White exhaust smoke?? | junbug | 95.5-2004 Tacomas & 96-2002 4Runners | 35 | 03-21-2005 07:37 PM |
| Help! White Smoke Again | Cooper04 | 95.5-2004 Tacomas & 96-2002 4Runners | 7 | 05-29-2004 09:38 PM |
