| Home | Photo Gallery | Register | All Albums | Blogs | Forum FAQ | FlashChat | Members List | Calendar | Search | Today's Posts | Mark Forums Read | Vendor Directory |
| Notices |
| Welcome to Yotatech! |
Thread Tools | Search this Thread |
#1 (permalink) | |||||
22re: very high high idle, very low low idle
#2 (permalink) |
my truck does the same...i was told that it was very common and what it is doing is that our engine has a auto choke and does that till it's completely warm then idles back down but as with you mine does idle a little rough (the needle sits just under a little bit of the 1 grand point on the tach) so im not sure if that is normal or if i need to fix it.
#3 (permalink) |
Same here. I might be getting the whole fuel delivery system cleaned, if so will post results. My idle also "sticks" and I have to tap the pedal to drop it to normal. I believe this is a clogged dashpot from research, might clean that this week and see what happens.
__________________
Former trucks- 89 & 86 4Runners http://www.va4roc.com |
#4 (permalink) |
Sounds like your choke is sticking on your 22RE. The choke is "sticking" and is not responding to the change in temperature of your engine, and justing the fuel/air ratio like its supposed to. So, either replace the auto choke, or install a manual choke that can be adjusted from the cab, that is a bit more of a hassle to use, but you get used to it.
__________________
-David '98 4Runner: SAW/OME lift, TJM bumper, Warn M8000 winch, Hayden tranny cooler, Trail Carnage front and belly skid plates, PIAA fogs, Rock lights, 33" MT's on Tech1 Rockcrawler rims, Lars sway bar discos, Sonoran bumpstops and rear bumper, RB 1" body lift, Daystar front bumpstops '73 FJ40: 327 SBC, York, Dual Batteries, custom tire carrier, Corbeau Baja SS bucket seats, Bestop top. TLCA#14428 |
#5 (permalink) |
I'd inspect all vacuum lines for leaks and check the t-body to see if it needs cleaning.
#6 (permalink) |
Yes , like Arnold said clean the throttle body. Also check the throttle position sensor .
#7 (permalink) | |
Quote:
mike |
#8 (permalink) |
Mike
You're right, for some reason I thought the 22RE engine was old enough to still be carbed, my bad!
__________________
#9 (permalink) | |
Quote:
Don't go asking for a new one of those at the parts desk. Anyway, I bet if you clean the throttle body it will solve the problem.
__________________
- Jamie 1996 4Runner SR5 4X4 Auto Deckplate Mod, Hayden Tranny Cooler, Amsoil Air Filter, OME 881/906 N86C/N91SC Lift Best OBD II scan tool I have used!. .....and I am AMERICAN! |
#10 (permalink) |
Yeah, showing my age a little, I think there are fewer and fewer of us who have ever owned/driven a car with a carb.
__________________
#11 (permalink) |
Location: White Mountains, Arizona (Yes it does snow in AZ)
What 22re's do have is a cold start injector. When it's cold it uses this gadget to adjust until it heats up. Set your idle (warm) back up to 750 and have the csi checked... some others to check on would be the tps, and throttle body cleaned.
__________________
Rigs: Way to many over the years to list. Current ones are- 1988 xtra cab, 84 beater.... more to come I am sure. If you can't dazzle em' with your brilliance... just baffle em' with your bull |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| 22RE-High Idle Problems (and a few others) | 93ToyKid | 86-95 Trucks & 4Runners | 8 | 06-15-2007 10:15 PM |
| 22RE High Cold Idle | all_terrain17 | 86-95 Trucks & 4Runners | 6 | 04-10-2006 05:04 AM |
| Low Idle - '86 22RE Pickup | elmo908 | 86-95 Trucks & 4Runners | 3 | 01-26-2006 07:06 PM |
| 22re startup idle is low | Yamaha+Toyota=Fun | 95.5-2004 Tacomas & 96-2002 4Runners | 5 | 11-10-2004 02:55 PM |
| Does low idle=more power & high idle=less? | Yoter | 95.5-2004 Tacomas & 96-2002 4Runners | 1 | 08-13-2004 06:11 PM |
