22re startup idle is low
Sorry guys but I got another question about the idle on my truck. Recently it seems like my truck has been starting up wierd when it is warm. In the mornings when I start the truck its totally fine idles up and everything then once its warm it idles at about 900 rpms. The problem I am having is after the truck is warm and I try to start it it starts but idles at like 400-500 rpms sometimes lower. Then after I drive around for like 2 mins its back up to about 900 rpms. I dont even have a clue were to start with this one so if someone could help me out....
I have heard thers is an individual fule injector that functions only for start up and that might be cloged. That happend to me and I had really rough startups. You mihgt check your throtle body and make sure it is sealing corectly. Other than that, I don't know for sure. I know my idle is often all over the charts as you described for no reason too.
I checked the tps and everything was ok except when i test with the throttle paritally open i get no resistance, I was going to take off the tps and check it out but there is a radator hose in the way. Ill check out the cold start injector, but will having a rich condition cause the truck to idle really low. I would seem to me to be the exact opposite, but ill check it out. Also how do you check the timing on a this motor?
