YotaTech Forums
Go Back   YotaTech Forums > Toyota SUV & Truck Tech > 95.5-2004 Tacomas & 96-2002 4Runners
Sign in using an external account
Register Forgot Password?
Search
Welcome to Yotatech!
Welcome to Yotatech,
LinkBack Thread Tools Search this Thread
Old 11-02-2004, 02:20 PM   #1 (permalink)
Personal Sales Rating: (0)
bain's Avatar
Send a message via ICQ to bain
22re running rich
whats the best way to lean out my motor? my exhaust has a gassy smell..if its adjusting the MAF ,,is clockwise or counter clockwise lean? thanks
bain is offline
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiTweet this Post!
Old 11-02-2004, 03:16 PM   #2 (permalink)
I'd say find out what is making it run rich now before messing with the maf. It could be a tired/dirty o2 sensor telling the ECU it is running lean when it isn't. Kind of a stretch, but I have had good luck with cleaning the o2 on my '85 4Runner and getting better mpg afterwards. This is combined with looking for exhaust leaks. If there is an exhaust leak the o2 will read lean and tell the ECU to crank out more fuel. More fuel in turn can make the problem worse as the o2 gets soot built up on it. Even more likely, check the TPS to see if it set up right.
Apparently, the TPS on the 22re is well noted for getting out of adjustment and is something to keep track of.
After doing the tps and o2 and maybe a quick tuneup (running rich = fouling plugs), pull the power to the ECU for a while then take it for a drive and let it relearn what it needs to and see how the exhaust smells after that.
Fahrenheit 451 is offline
Yotatech
4WD Truck
Paid Advertisement
Tags
22, 22re, clockwise, counterclock, exhaust, fouling, lean, maf, plugs, rich, running, smell, smells, strong, wise
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Similar Threads
Toyota Running Rich/Running Lean? NEED HELP! mrboyertown Newbie Tech Section 3 05-18-2007 12:19 AM
22RE running rich yotamanmn 86-95 Trucks & 4Runners 9 05-12-2007 04:19 PM
22RE running rich cweich 86-95 Trucks & 4Runners 9 10-03-2006 10:15 PM
what is running rich vs running poor arielb1 95.5-2004 Tacomas & 96-2002 4Runners 4 02-20-2006 02:19 PM
22re running rich stevrock 95.5-2004 Tacomas & 96-2002 4Runners 3 12-30-2004 11:29 AM
2010 InternetBrands, Inc.
Search Engine Friendly URLs by vBSEO 3.5.2
